Minecraft Server vs Technicolor TG582n
- Minecraft Server vs Technicolor TG582n
29-04-2013 11:28 AM
Hi guys,
I have tried setting up the Game ports in the "Game & Application Sharing" section and have correctly routed it to the PC that the server is running on. I can access the sever over the LAN but for some reason port 25565 just won't open up.
In fact, when I try and check what ports are open, when using an external web service to check, apparently none of my ports are open at all. 😕
The firewall is set to standard so it's not blocking anything. UPNP is activated fine, so I'm a little stumped.
Any ideas?
Any ideas?
Message 1 of 5
(1,562 Views)
4 REPLIES 4
Re: Minecraft Server vs Technicolor TG582n
29-04-2013 1:56 PM
No other Minecraft geeks out there able to offer advice?
Message 2 of 5
(693 Views)
29-04-2013 3:23 PM
If you check the router's settings, are the ports/IPs still bound when you go back to the relevant page?
Message 3 of 5
(693 Views)
29-04-2013 3:54 PM
They are are yes. I can connect to port 80 via telnet not problem, but 25565 just doesn't happen.
Message 4 of 5
(693 Views)
29-04-2013 4:14 PM
Ok, I just did a wipe of the router to make sure it wasn't anything I had done. Set everything up again, while the port is still marked as closed, people can access the server! Very weird, but at least it works!!
Message 5 of 5
(693 Views)
