Migrating In - When?
- Migrating In - When?
28-03-2008 9:03 AM
I'm migrating in to PlusNet onto BBYW Option 2. I've got my MAC code and been through the signup process. My order tracker says "Your move is due to take place on as soon as possible." - will PlusNet give me a date, or do I just have to wait still my connection stops working so I can change the router settings?
Thanks!
Thanks!
Message 1 of 7
(1,456 Views)
6 REPLIES 6
Re: Migrating In - When?
28-03-2008 9:39 AM
You will get an email once we receive the date from BT in our automated reports.
I have however just checked this for you manually and can see that the migration is due to happen on Wednesday 2nd April.
Message 2 of 7
(628 Views)
28-03-2008 9:46 AM
Excellent - thanks!
Message 3 of 7
(628 Views)
31-03-2008 11:49 AM
Quote from: Mand Hi there,
I haven't had an email confirming this, and the order tracker still says it's "due to take place on as soon as possible."
Should that show the real date? Am I still on for the 2nd?
Message 4 of 7
(628 Views)
31-03-2008 12:00 PM
Hi Talpa,
I've just checked your order on the BT system and can see it's due to be completed on Wednesday (2nd) so yes, it's all still on schedule.
Hope that helps,
Hope that helps,
Message 5 of 7
(628 Views)
31-03-2008 12:12 PM
Quote from: orbrey Hi Talpa,
Hope that helps,
OK - but should that not be showing on my order tracker?
Message 6 of 7
(628 Views)
31-03-2008 12:17 PM
It depends, in some cases where the order has been progressed manually it won't show the status - I suspect this is the case with your own. However we still receive the same completed order from BT and the line will still activate automatically when it does complete.
Apologies for the hassle though.
Message 7 of 7
(628 Views)
