Migrated from Be/Sky to PlusNet - Lower than expected Sync
- Migrated from Be/Sky to PlusNet - Lower than expec...
- « Previous
- Next »
Re: Migrated from Be/Sky to PlusNet - Lower than expected Sync
21-02-2015 11:55 AM
I'm using the DG834v4 at the moment, doesn't seem to like much below 20s unfortunately
As for the manager, that's pretty much what I went through with him this morning. He was very much of the attitude of, "you're not getting into restricted areas, if OpenReach want to come out that's fine, but you can piss right off"
Currently experiencing another REIN burst, so popping downstairs to check that box.
Message didn't post, but had it saved. Went downstairs and checked that box, didn't seem to be any different intensity-wise. When I got back up, I'd resynced at 11mbps with a 5dB SNR, looks like it dropped out a few tones. Interference is still going strong, lots of noise coming from Co-Op at ~ 600kHz, will pop back down later to check their plant room from the outside to see what it's like without the interference in my flat. If it's gone, we know they're the culprit.
Whatever it is, it's lighting up every single electrical device in the entire shop. Everything spits out RF at that frequency in there; fridges, LCD displays, EVERYTHING. It's like whatever noise is being generated is transmitting down every single power line they have in the building, making the entire thing act like one massive antenna.
21-02-2015 12:00 PM
21-02-2015 12:17 PM
21-02-2015 12:36 PM
That interference near 600kHz seems to be ~582kHz on the last graph, and seems slightly stronger than previously. However the interference ~1300kHz has been consistently a much stronger harmonic.
I'd still clarify with the manager "I wouldn't be asking for access to non-public areas if I think I've found something that suggests it could be a piece of your equipment, just for you to switch it on and off whilst I check the interference levels. I would hope for your co-operation in that."
If he tells you to **** off or even threatens to ban you from the store, I would get straight onto head office but not even warn him of that.
21-02-2015 12:41 PM
21-02-2015 12:45 PM
21-02-2015 12:47 PM
Make sure you are now logging when the REIN is occurring and can establish some patterns, because when this ultimately gets raised to BTw/Openreach for a proper REIN engineer (of which there are few), you would obviously want them to turn up when the REIN is most likely to occur.
Wrote the above before your last post.
21-02-2015 12:50 PM
Quote from: mdc I called up PlusNet and its being escalated to OR as a REIN issue.
I hope that actually happens, post the ticket number here, so one of the Tech CRT guys can keep an eye on it and chase it if needed.
23-02-2015 9:29 AM
12-03-2016 11:58 PM
So for the past year I've had - at best - a 10mbps service on a line that I KNOW can do double that. Unfortunately, despite the fact that across the road from me (literally 50 feet away) the houses can all get FTTC, I'm stuck on a direct DP with no chance of ever getting fibre, and no cable either. At this point I'm seriously going to have to consider moving, which is a shame because I really did like this place, and I've been here for 5 years. But half of that without a reliable or reasonable connection, in my line of work, makes things extremely difficult.
On top of that, since my 12 month introductory offer has since lapsed, I'm now paying double for half the service I was expecting, so will most likely be cancelling my subscription as well. To everyone who gave advice, thank you very much, and to PlusNet, I'm disappointed that things never got fixed but since the infrastructure is managed by OpenReach, I understand there's little else you can do.
13-03-2016 12:46 AM
In a situation such as yours, you might try taking the matter to your parish council and your MP. Both are likely to have a keen interest in getting high speed broadband rolled out, especially if it is a rural area.
13-03-2016 2:47 AM
Unfortunately, I'm smack bang in the middle of a city and between 50-100 feet away from a FTTC enabled cabinet. The building, however, is a block of flats served by a direct trunk to the exchange, and it "doesn't make economic sense" for them to roll out fibre to serve those 30 flats. The coverage in the area of FTTC is > 90%, so there's no motivation for them to do anything. Even digging up the road to run a short fibre trunk to the building has been deemed "not financially viable" by Openreach, so I'm basically SOL. I wouldn't have minded so much if I was at least able to get my 20mbit back (line to the exchange is about 1km, so fantastic for interference-free ADSL, but useless for VDSL as well.
13-03-2016 7:21 AM
Whilst the pattern of occurrence seems random, you seemed fairly convinced at the time that it was some equipment possibly lighting at the Co-op, if that's still the case, is there any pattern to the time "bands" when it occurs or does not occur - eg. does it ever occur when the store is closed? Does it tend to occur mainly at times when shelf restocking is happening?
This sort of profiling my help narrow it down a bit - even if it's not the Co-op, profiling in that way may help you consider other sources - eg. it only happens when flat A is occupied etc.
If you still think the Co-op is the likely source, does it still have the same unhelpful manager?
13-03-2016 12:19 PM
13-03-2016 1:50 PM
mdc, whether you don't tell the manager you are going to do that, or ask him for the Head office address & phone number could an interesting ploy, but going to the local media with a headline of something like "Electrical equipment at local Co-op suspected of causing interference to Broadband" might prove interesting.
But I think I would try profiling the time-slots as best as possible first. Then when you get the interference, wandering into the store - pretending to be shopping - with a radio in your pocket and your earplugs in your ears (there are so many people wondering around listing to their iPhone or mp3 player etc I'd think nobody would pay particular attention). See if the signal is stronger in the store and see if there's a particular area where it comes up strongest.
That of course is easier to say than it will be to achieve in practice.
- « Previous
- Next »
