Microsoft Lync and Ellanoya
- Microsoft Lync and Ellanoya
28-11-2011 11:16 AM
According to http://community.plus.net/library/faults/using-wireshark-for-data-capture/
It looks like the voice data via Lync is classed as Silver. E.g. look at frame 4.
Have I read that correctly? Can we make it Titanium please?
3Mb FTTC
Re: Microsoft Lync and Ellanoya
28-11-2011 12:11 PM
28-11-2011 1:27 PM
3Mb FTTC
28-11-2011 2:17 PM
Zip the file or change the file extension to .zip and try that.
Edit: make sure this condition is met http://community.plus.net/forum/index.php/topic,94089.msg791322.html#msg791322
Yet more info http://community.plus.net/library/faults/using-wireshark-for-data-capture/
28-11-2011 2:22 PM
28-11-2011 3:29 PM
3Mb FTTC
18-12-2011 5:22 PM
3Mb FTTC
06-02-2012 3:09 PM
3Mb FTTC
07-02-2012 2:15 PM
Sorry that's been so long. I've asked one of the guys who looks after that pool to go and have a look for you, there should be an update on there this afternoon.
07-02-2012 7:23 PM
Quote Dear Mr XXXX,
We've reviewed the attached Wireshark capture files and unfortunately we've not been able to integrate this program into our traffic management platform. This is because there are neither any identifying features in the UDP data nor any regularly used ports.
I would advise that if possible you set your client or server to use a standard SIP/VOIP port or purchase the Pro add-on.
I understand that this is not a good outcome but unfortunately there is nothing further that we can do.
Kind regards,
ZZZZ
Ah, PN is not fit for purpose.
3Mb FTTC
29-10-2012 2:35 PM
3Mb FTTC
29-10-2012 3:11 PM
We actually think we have some good news on this for you, but have held off on a reply until we have some details on when we intend to deploy this.
As of afternoon on Wednesday (24th), we have received notification from our suppliers that they have located a method to detect the Microsoft Lync traffic. I have authorised them to proceed to build the needed signature using this method within the hour of them sending us this information.
I do wholeheartedly agree this has taken far too long.
Microsoft Lync has been by far the most challenging one to detect. It uses a UDP stream of encrypted data and to anybody that didn't know you were using Lync, would look like a purely random byte stream.
Although far from the only causes, we have switched traffic management platforms in the middle of this and our suppliers have further complicated it by not responding, which has also impacted other work we are doing. It's by far the longest and most complex case we have had though (with exception of one other, but that is only as the customer that reported it is no longer with us to assist).
Once these updates are available, this will go through our change control process for deployment. I'll be providing you with a date directly when that is available, so you get a before and after feel for this.
06-11-2012 1:46 PM
3Mb FTTC
08-11-2012 9:07 AM
We have deployed the changes to the traffic management platform this morning.
Per some of the details above, MS Lync is most certainly one of the more technically challenging ones we have dealt with. As a result, there is a level of expectation that it may not work, or rather may not work every time.
There is a high level of confidence that this will solve the majority of issues, certainly provided your network was is a similar setup to when the latest capture was done.
Can you try this for us and let us know the experience? On top of this, if there are any further issues, we will need some new captures and the instructions previously supplied will apply (if this is needed, we may need more than the traditional 2, though we will advise if the becomes a requirement).
11-01-2013 4:56 PM
3Mb FTTC
