May be I should be re-interleaved?
- Re: May be I should be re-interleaved?
01-07-2013 9:16 AM
Both prior to its removal and since my sync has been around 8000 kbps and SNRM 3 dB.
Graphs of my CRC errors concern me, whether with good reason or not I do not know. Even though the hourly average CRCs/minute is well under 100, at periods the average is very much higher.
To get the stats router and computer were ON overnight, but between midnight and 6 am.there was no activity.
Copies of the relevant graphs are attached.
As I am not a gamer, do I need fast path, and should my connection be changed to interleaved?
01-07-2013 2:17 PM
Would you like me to do this?
01-07-2013 2:35 PM
Your connection isn't dropping so I don't see any value in doing this.
If it's not broke, don't fix it
01-07-2013 7:52 PM
Thanks both for your replies, which seem a little contradictory
It has been suggested to me, that eventually DLM will notice the errors and increase the SNRM target, whilst others say that applying interleaving could be ineffective, because the MSAN on ADSL2+ is aggressive and would soon apply fast path.
Time for iced bag!
Comments?
01-07-2013 11:10 PM
02-07-2013 7:53 AM
Quote from: chrispurvey With the errors you're getting on your line it would certainly be worth putting interleaving on first as this should improve things for you.
Hi Chris! Please give it a whirl! When will it become effective?
Thanks.
02-07-2013 10:48 AM
Happy to do this but just want to say before we do - it's currently set to Auto, so the DLM system evidently doesn't seem to think it needs to be on, not sure if that changes your mind but thought I should mention it before we go ahead?
02-07-2013 11:29 AM
02-07-2013 11:37 AM
02-07-2013 3:53 PM
02-07-2013 3:58 PM
02-07-2013 4:20 PM
03-07-2013 9:10 AM
Quote from: James Interleaving orders complete at the start of the next working day.
What time is that? Connection still showing as fas path, router having been rebooted.
03-07-2013 12:54 PM
03-07-2013 6:47 PM
