Max ADSL, PAYG and BBYW
- Max ADSL, PAYG and BBYW
15-11-2007 4:56 PM
I'm on a fixed 2MBps line speed on PAYG (Speed test regularly returns around 1.89 mbps).
My usage is creeping up all the time so my 4 GB per month limit will inevitably become inadequate. I really don't want to suffer the slow speeds of traffic shaping and that is what is keeping me on PAYG.
I then thought .... , if I went for up to 8 MBs with line showing Noise at 25Db and Atten of 40 I guessed at getting a stable rate of between 3-4 Mbps - any degraded service through traffic shaping would probably see me maintaining adequate speed of around 1.5mbps.
Is my logic flawed? I'd be grateful for a view.
Message 1 of 5
(1,455 Views)
4 REPLIES 4
Re: Max ADSL, PAYG and BBYW
15-11-2007 5:01 PM
Depending on what you use your connection for you might find the page linked below useful. It gives information on the expected speeds for each BBYW account. (BBYW Pro has no rate limits or management applied before the 10GB allowance).
BBYW Speeds
BBYW Speeds
Message 2 of 5
(516 Views)
15-11-2007 5:01 PM
It's flawed but in a good way
With those line stats I would expect you to see speeds in the region of 5-6Mbps, exchange contention permitting.
You should get line rate on HTTP traffic. It is just specific forms of traffic that would experience a different quality of service, namely P2P and Usenet traffic.
As per this page you will be able to see expected speeds across our Product Range, which I hope will give you a better understand of the product. I also really think it will be a lot better than you currently expect it to be.
Message 3 of 5
(516 Views)
15-11-2007 5:09 PM
I'm really sceptical about this - why do you think many posts say that BBYW is sluggish compared to PAYG then?
Message 4 of 5
(516 Views)
15-11-2007 5:15 PM
Nothing wrong with scepticism
Those posts will not be referring to "gold" traffic such as email and HTTP. As I mentioned above, the main differences are related to P2P and Usenet.
It will depend entirely on what you use your connection for.
Message 5 of 5
(516 Views)
