Master Socket Faulty
abbiewedge
Hi there, I’ve just moved into a new house which already had a master socket 5c port therefore we didn’t need an engineer. However our Plusnet router is not working when I wire it up to the master socket.
I’ve removed the face of the master socket in case it was faulty but no luck there. The master socket seems to be running into an aerial box but we don’t have an aerial input on the Plusnet router.
Any help would be great!
17 REPLIES 17
mystreet1
Seasoned Pro
Fixes: 7
Re: Master Socket Faulty
Can you post some photos of the setup.
Will help greatly
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
abbiewedge
abbiewedge
Thanks! The master socket seems(?) to connect to the telewest broadband wall socket which has a coaxial coming out of it. There's also two adapters coming out the wall, with very loose wires attached.
Fixes: 392
@abbiewedge It LOOKS like the previous people were Telewest/Virgin customers, and the cabling for that, for some reason was wired through the BT box -  wrongly.
You need someone to remove the Telewest stuff and wire the 5C box correctly - that someone being Openreach.
abbiewedge
Oh no, so i'll have to wait a month for Plusnet to send an engineer out  😞
Fixes: 392
No, you don't have to wait a month - if you report your problem, I see no reason why it wouldn't be resoled inside a week.
abbiewedge
Oh great, I only say that as engineer set up wait times were a month.
Fixes: 392
Different engineering staff, and different issues.
abbiewedge
Gotcha, thanks!
It could be the hole through the wall to outside could be shared with the coax cable and copper landline using it.
What is the Hubs lights showing, Orange, Flashing Orange?
Fixes: 392
@Dan_the_Van Possible, I suppose, but theTW kit needs removing - IMO.
@jab1
The equipment is not owned by @abbiewedge TW now Virgin Media should be asked to remove it.
Fixes: 392
I'm aware of that, but looking at its age, I doubt they would want it back, so I see no reason why any competent person couldn't remove it.
I would suggest at this stage the hubs light status would be the best indicator of the next steps anything else would be a distraction.
Flashing Orange - this would indicate there is an issue with the broadband signal, not preset
Orange - there is an problem with the incoming signal
Red - there is something wrong
Red and Orange can look similar.
