Massive slow downs at peak times
- Massive slow downs at peak times
19-05-2011 9:13 PM
never had slow downs at peak times just the last two days i have reconnected it didnt make a difference
my exchange is green cap
bt.speedtester just says theres an error when i try and use it
my IP profile is 15 on plusnet
and 14.8 with BT.
Re: Massive slow downs at peak times
22-05-2011 6:50 AM
22-05-2011 7:01 AM
22-05-2011 8:33 PM
22-05-2011 10:20 PM
22-05-2011 10:29 PM
22-05-2011 10:31 PM
22-05-2011 10:33 PM
"did you know theres a pro add-on"
ha i will flip if someone suggests that
22-05-2011 10:36 PM
22-05-2011 10:49 PM
I'm connected to ptn-ag04.
VP capacity at this exchange is currently showing as Green.
anyways i'll phone tomorrow and see what they say.
22-05-2011 11:02 PM
23-05-2011 11:25 AM
anyone want to see my BT speedtest? lol
Download speedachieved during the test was - 15989 Kbps
For your connection, the acceptable range of speedsis 4000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :16231 Kbps(DOWN-STREAM), 984 Kbps(UP-STREAM)
IP Profile for your line is - 13000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 37.49:19.61:42.9 (SBE:NBE
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
what the.... like 2% overhead
anyways
i've logged a fault but i can see this dragging on.
23-05-2011 12:45 PM
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
23-05-2011 3:36 PM
i have to test over the next few days.
24-05-2011 1:06 PM
the speeds have been fine owell...
