Masive drop in speed again.
jld51
1. Best Effort Test:  -provides background information.
Download Speed
7.04 Mbps
0 Mbps 77.44 Mbps
Max Achievable Speed
Download speedachieved during the test was - 7.04 Mbps
For your connection, the acceptable range of speedsis  40 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
13.66 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 13.66Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit the FAQ if you are unable to understand the test results.
jld51
Re: Masive drop in speed again.
Just to add no noise on line ,wired connection speed was steady at around 65- 72 Now like a snail...........
Hi
Which exchange are you on?
Fixes: 67
Hi jld51,
Diagnostics aren't revealing anything obvious to me so I'd get that reported here as soon as you can: http://faults.plus.net
Adam
 Adam Walker
