Major drop in download speed
weeally46
Re: 2 days after a fixed fault broadband is slowing down again. Cmon
The local area powercuts were to do with bad weather, which seems to have got better for now.
weeally46
Hi @Townman
The modem has no offest applied to the SNRM, I only use this for troubleshooting ocassionally.
I can't run router stats and I don't have a plusnet hub one to try. I do however have a old BTHH2, that syncs at pretty decent speeds.
Fixes: 160
Internet Software (vwlowen.co.uk)
"RouterStats -Lite also has a "user-defined" router which should allow you to configure it to work with other routers not listed. This option isn't plug-n-play but should be relatively easy to set up."
It might work with the BTHH2
RouterStatsHub :: RouterStats for the BT Home Hubs 3 & 5 (vwlowen.co.uk) might be worth a poke - I have no idea of the similarieis (or not) of BTHH2 & 3.
weeally46
Hi @TheMightyAJ The DLM reset has went through, the modem is syning at 6db again and 18296kbps.
I will keep an eye on this over the next few days and let you know how it goes.
TheMightyAJ
Fixes: 126
I'm glad to hear that's improved the speed somewhat! Just give me a shout if there are any issues and I'll get back to you as soon as possible Smiley
 Alex H
