Mailbox sending limit?
wilfy
Is there a restriction on the size an e-mail can be to send / receive?
I am trying to send a 110mb file across outlook
Many thanks
wilfy
Fixes: 24
Re: Mailbox sending limit?
The simple answer is 'Yes'.  I'm not sure what it is and if it is the same for all email systems but there is definitely a restriction.
Fixes: 21
I believe the Plusnet message size limit is 100M which means the attachment has to be smaller as I understand MIME encoding can increase attachment size by upto 30%. However, the recipient may have a smaller size limit, I think gmail is 10M (not sure). Try zipping the attachment if the recipient can receive OK.
acr
With Gmail you can send or receive up to 25MB.
http://support.google.com/mail/bin/answer.py?hl=en&answer=8770
When sending through a client, our servers will allow up-to a 100MB file.
Email clients will differ on what would size file can be sent through them, I'm not 100% certain on Outlook.
It may be worth having a try of something like dropbox when sending files of this size.
Fixes: 10
That's slightly misleading Chris.
The servers allow an up to 100MB total message size (not each attached file). When  files are attached they are encoded which increases the size. As a rule of thumb the total of all attachments in an email needs to be less than 80MB.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Thanks for the correction jelv, that was what I was trying to imply  Wink
Fixes: 21
Which is what I said in reply #2.
