Mailbox password not recognised
- Mailbox password not recognised
30-09-2007 6:22 PM
Last week I created new mailboxes for family members. I was able to access these mailboxes via Webmail and from my email client (Outlook).
When I try to do the same thing today, I get an error message stating 'Unknown user or password incorrect ' from Webmail. The username and password were definitely entered correctly. Also, outlook cannot receive emails from these mailbox accounts stating 'There was a problem logging onto your mail server. Your User Name or Password was rejected.....'. The username and passwords configured in Outlook are definitely the same as the ones used to set up the mailbox.
Interestingly, this is a problem for 3 out of 4 mailboxes. One of them can be accessed successfully.
Any ideas what I'm doing wrong here?
Message 1 of 7
(1,860 Views)
6 REPLIES 6
Re: Mailbox password not recognised
30-09-2007 8:33 PM
Is the mailbox that works the username one whereas those giving problems are additions?
Have you by any chance forgotten to use username+mailboxname as the login name for those additions?
David
Message 2 of 7
(807 Views)
30-09-2007 8:42 PM
The mailbox that works is one of the username+mailboxname type. I have 3 others of the same type (with different mailboxnames) and they don't work - but they did when I originally set them up which is what I can't understand.
Yes, I am using the correct username+mailboxname login name on both webmail and outlook.
[My username mailbox also works fine and always has done.]
Thanks for replying.
Message 3 of 7
(807 Views)
30-09-2007 8:43 PM
I had this problem myself sometime ago.... You need to raise a fault ticket, nothing you can do will fix this problem.
If it helps them my fault ID was 21933060. Took them 12 days to resolve my issue, perhaps they will be quicker with you.
Dan...
Dan...
Message 4 of 7
(807 Views)
30-09-2007 9:34 PM
Dan - thanks for the advice. Have raised a ticket and quoted your fault id.
Message 5 of 7
(807 Views)
01-10-2007 8:56 AM
I've just tested a couple of your mailboxes and can log in to them without problems. Shout up if the problem carries on for you and I'll have another look.
Message 6 of 7
(807 Views)
01-10-2007 1:19 PM
All working fine now. PlusNet support fixed it within a hour of raising the fault ticket
Message 7 of 7
(807 Views)
