Mac Key Problems
- Re: Mac Key Problems
Mac Key Problems
11-03-2014 11:54 PM
I'm moving from BT to plusnet, during ordering I was asked for a Mac Key I provided it and was told it was invalid, phoned BT they comfirmed it was the correct key, not sure what to do....
Help anyone
Help anyone
Message 1 of 6
(694 Views)
5 REPLIES 5
12-03-2014 9:30 AM
Hi batgirl2610,
I'm sorry to hear of this issue 😕
Could you PM me your MAC Code so I can take a look at it for you?
Message 2 of 6
(443 Views)
12-03-2014 11:25 AM
ok will do if i can figure out how (not very computer savvy)
Message 3 of 6
(443 Views)
12-03-2014 11:35 AM
I had similar problems with my MAC; it was the PN agent not using the correct upper/lower case on entry.
Message 4 of 6
(443 Views)
12-03-2014 11:36 AM
batgirl if you look under your name in the post you have made, below that you should see the number of posts and then three icons under that, the right icon is PM, so if you look above and click on the right one under Chris Pettitt you should then get the PM box and options to send Chris the MAC code, hope this is of some help to you
Message 5 of 6
(443 Views)
12-03-2014 11:51 AM
Yeah - the MAC Code in this instance is too short (Only 12 characters long).
Message 6 of 6
(443 Views)
