MY ANNOYING BROTHER!!!!!! And Lack Of Bandwidth
- MY ANNOYING BROTHER!!!!!! And Lack Of Bandwidth
17-04-2008 9:55 AM
Re: MY ANNOYING BROTHER!!!!!!
17-04-2008 10:51 AM
17-04-2008 11:00 AM
17-04-2008 11:03 AM
Re: MY ANNOYING BROTHER!!!!!! And Lack Of Bandwidth
17-04-2008 11:07 AM
17-04-2008 11:12 AM
17-04-2008 11:12 AM
Have you offered to pay the extra yourself?
17-04-2008 11:14 AM
17-04-2008 11:18 AM
I can see his point though. Learn to stay within the bounds - you only have a day to wait - be patient!
17-04-2008 11:21 AM
17-04-2008 11:23 AM
17-04-2008 11:31 AM
You can add a one off GB to your account for an extra £1 to be paid tomorrow and then next month it will simply revert back to previous cost.
If you go into the view my usage tool on the portal, you should see a button that says upgrade, if your currently restricted then your on fixed cost, if you tick the box in the upgrade process to go to flexible, but leave your account at 20GB it will automatically add a GB to your account, then next month you can go back into the same section and change it back to being fixed at 20GB
Hope that helps
17-04-2008 11:36 AM
17-04-2008 11:37 AM
17-04-2008 11:51 AM
