MTU settings
- Re: MTU settings
MTU settings
29-07-2012 10:27 AM
Anyone know what the optimum MTU setting is for routers on PN please?
I know that 1500 is the default setting on the majority of newish routers and I believe most ISPs tend to trim the value for their servers.
Thanks in advance
Thanks in advance
Message 1 of 5
(13,272 Views)
4 REPLIES 4
Re: MTU settings
29-07-2012 10:33 AM
With the router MTU set at 1500 run the following command
If that works, 1500 is the correct setting for you.
ping -f -l 1472 ntp.plus.net
Message 2 of 5
(3,875 Views)
Re: MTU settings
29-07-2012 10:51 AM
My router MTU was set at 1492 and the reply came back
"Packet needs to be fragmented but DF set"
I then changed it to 1500 at got
"Destination net unreachable"
What's the right answer?
Message 3 of 5
(3,875 Views)
Re: MTU settings
29-07-2012 11:10 AM
thanks jelv.
I'll give that a try.
Message 4 of 5
(3,875 Views)
Re: MTU settings
29-07-2012 12:09 PM
@ReedRichards
"Destination net unreachable" is not the right answer!
You should get (note that because of the larger packet size, latency will be increased from a normal ping):
If you reduce the 1472 in steps of two you will find the maximum packet size that will be accepted without fragmenting. The router MTU should then be set 28 higher than that figure.
We have in the past seen issues where particular Plusnet gateways have had a problem with MTU 1500. I'd have hoped that these were long behind us, but it might be worth seeing if you get the same result on a different gateway when using 1500.
(Note this guidance relates to PPPoA connections only, for PPPoE connections the maximum possible MTU is 1492)
C:\Users\John>ping -f -l 1472 ntp.plus.net
Pinging ntp.plus.net [212.159.13.50] with 1472 bytes of data:
Reply from 212.159.13.50: bytes=1472 time=37ms TTL=250
Reply from 212.159.13.50: bytes=1472 time=36ms TTL=250
Reply from 212.159.13.50: bytes=1472 time=35ms TTL=250
Ping statistics for 212.159.13.50:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 35ms, Maximum = 37ms, Average = 36ms
Message 5 of 5
(3,875 Views)
