MTU setting ?
- Re: MTU setting ?
MTU setting ?
27-08-2012 12:16 PM
Hi ..
what should this be ? am using belkin N150 ... on my old belkin it was something 1430 .. but new belkin shows 1500 .... just wondered if this needed to be adjusted
thanks
thanks
Message 1 of 9
(2,201 Views)
8 REPLIES 8
Re: MTU setting ?
27-08-2012 2:33 PM
An MTU setting of 1500 is the normal Windows default. There is no need to change it in normal circumstances.
David
Message 2 of 9
(690 Views)
Re: MTU setting ?
27-08-2012 3:13 PM
Hi
thanks for that , it seems everytime my connection is reset by BT/PN eg IP profile i get a MTU fault on XBOX live and 100% packet loss , i tend to have to restart my router again to get my mtu back !
any ideas ?
cheers
any ideas ?
cheers
Message 3 of 9
(690 Views)
Re: MTU setting ?
27-08-2012 3:38 PM
Is the UPnP setting different on your old router and new one? Perhaps the gaming community are better placed to help with this problem,
David
Message 4 of 9
(690 Views)
Re: MTU setting ?
28-08-2012 11:26 AM
UPnP setting is the same as old router i think ...
trouble is , when i reset the router to get MTU back ... BTW sees it as a disconection and then we head into a downward trend again ..
on my router if i log in and look at setting it shows 1500 .... but the text underneath says "Do not make changes to the MTU setting unless your ISP specifically requires a different setting than 1454" ...so am right in thinking that it should be set 1454
cheers
cheers
Message 5 of 9
(690 Views)
Re: MTU setting ?
28-08-2012 3:24 PM
In my opinion it should be set to 1500 unless problems are encountered with some graphics rich websites. I think such problems are probably hardware dependent especially with regard to graphics cards. In this case 1400 usually works.
I believe 1454 is the theoretical optimum for PPPoE over ATM to ensure there is no wasted space in an ATM cell if all transmitted TCP packets are maximum length. The calculated benefit from this is a boost in download speed of around 90kbps. We use PPPoA which has diiferent overheads. Amidst the vagaries of the Internet is 90kbps worth bothering about?
David
Message 6 of 9
(690 Views)
Re: MTU setting ?
28-08-2012 4:01 PM
Absolutely correct spraxyt - an explanation here: http://www.mynetwatchman.com/kb/adsl/pppoemtu.htm
Not all routers report the 'true MTU' though and 1500 could be the 'correct' setting if that's already allowing for some of the overhead (sometimes reported this way to simplify things and reduce confusion but all too often has the opposite effect).
If you gradually reduce the setting until things work then you might find the 'optimum setting' but this would likely involve many rooter reboots which you are absolutely aware is not a good thing, given the small difference between 'optimal' and 'nearly optimal' I'd definitely recommend following the advice in the previous post and try 1400 at least to see if that solves the packet loss issue.
Call me 'w23'
Message 7 of 9
(690 Views)
Re: MTU setting ?
28-08-2012 7:53 PM
Thanks guys , although it sounds way to technical for me ! .. i raised a ticket and the reply seems to say that it could be a faulty router ... my previous router did have a different MTU setting and i never ever had this kind of problem , would there be any detriment to setting it at 1454 ?
cheers guys
cheers guys
Message 8 of 9
(690 Views)
Re: MTU setting ?
28-08-2012 8:14 PM
Shouldn't be much (if any) detriment other than the inevitable rooter reboot when changing such settings.
Call me 'w23'
Message 9 of 9
(690 Views)
