MTU setting on ADSL2+
- Re: MTU setting on ADSL2+
27-07-2011 9:16 AM
Can't seem to get to the bottom of this one. BT's Sinet documents state that the ADSL2+ system is optimised for PPPoE and therefore the MTU should be set at 1492. However, most users are using PPPoA to connect. Does this still mean that the MTU should be set at 1458 as before? I assume that the same encapsulation overhead occurs with PPPoA as it always did?
Message 1 of 4
(4,387 Views)
3 REPLIES 3
27-07-2011 10:56 AM
Message 2 of 4
(1,448 Views)
27-07-2011 1:43 PM
Where does it say that it's optimized for PPPoE? SIN 472 (WBC) page 11, and SIN 485 (IPStream Connect) page 13 both say the opposite:
"It should be noted that the use of LLC/SNAP and PPPoE incur a higher protocol overhead and therefore will
provide a lower throughput than the use of PPPoA/VC-mux."
Message 3 of 4
(1,448 Views)
27-07-2011 8:01 PM
Not sure what the document was, but last year I was shown a SIN by one of the more experienced BT Special Squad (!!!!!!) who fixed a PPPoA/oE fault for me. He pointed out that the backbone of the new ADSL2+ system is oE based. Can't be any more specific the that, sorry.
Message 4 of 4
(1,448 Views)
