MRTG stats for the 2704n router
jeffers
Not sure how much use this will be to anyone on here but I wrote a quick and dirty script to pull the ADSL stats from the plusnet 2704n router suitable for use in mrtg.
Heres a link to the code:
https://gist.github.com/potchin/44cfdf88b31af19ab7dc
and a quick blog post with some sample mrtg config and screenshots..
http://www.potchin.co.uk/2015/03/wow-its-been-while-since-i-put-anything.html
I'm sure there's some fellow stats geeks out there who like this sort of thing  Crazy
Fixes: 21
Re: MRTG stats for the 2704n router
Interesting, thanks for posting. I've made a note of the code, will try and look in more detail later. Strange I couldn't get the page with the code to open in IE - it is an old version, haven't bothered finding out why, it's fine in Firefox.
On the example screenshots, I was rather puzzled as to why your time axis runs from R to L rather than the conventional L to R.
jeffers
Right to left is standard for mrtg, no idea why. Ive gotten used to it. You can add 'growright' to the config to swap it Smiley
