MAC delay
- MAC delay
- « Previous
- 1
- 2
- Next »
Re: MAC delay
11-08-2011 10:49 PM
Oakstar
You done the above chap? You may find (as we discussed earlier ) that if you move you'll just migrate with the problem, would be easier to sort said problem out (Even if you believe the line is crystal-ball, it may not be). Then if your *still* unhappy, move.
unless i've missed something, have these things been checked? (As Alex hasnt made public, idk what hes done other than the Line Tests)
somethings definitely not right though to see that sort of throughput on speedtest. -- Did you know you can do jitter tests at pingtest.net too ? (Logs the results like ST.net)
Regards
Quote ok the best thing you can do is to log a fault at http://faults.plus.net/ so that we can investigate this further
Regards
Message 16 of 23
(593 Views)
Re: MAC delay
11-08-2011 11:00 PM
I think you'll find that being confrontational and abusive (however mildly) is not the best way to get help. I personally hope (based purely on your apparent attitude) your problems do go with you if you decide to move. Please learn to take a better attitude with people who are trying to be constructive, bear in mind that this is a community site and comments and suggestions come from all levels of expertise and experience and please make your posts more meaningful (for example what software or site is your last post based on please as without that information it's very difficult to confirm / refute or compare your results).
[edit:typos]
[edit:typos]
Call me 'w23'
Message 17 of 23
(593 Views)
Re: MAC delay
11-08-2011 11:36 PM
hi matt, yep done the other but going down the road of fault et c been there before no change.
Message 18 of 23
(593 Views)
Re: MAC delay
11-08-2011 11:45 PM
So if you're off to a LUU ISP who installs their own equipment in the telephone exchange there's at least a chance that your problem won't move with you. If that does not work out then you've just got to hope that your new ISP offers better fault-resolution than Plusnet does.
Message 19 of 23
(593 Views)
Re: MAC delay
13-08-2011 6:49 PM
as i'm leaving i couldn't give a monkey's, and it's LLU by the way
Message 20 of 23
(593 Views)
Re: MAC delay
13-08-2011 11:11 PM
it's saturday night and here we go again -
Download speed 2369 Kbps
Upload speed 353 Kbps
D/load COS 58 %
U/load COS 82 %
RTT 41 ms
RTT Consistency 78 %
Max Delay 135 ms
Avg Delay 14 ms
Max Bandwidth 5120 Kbps
Route Speed 12787 Kbps
Forced Idle 0 %
Route Conc 2.1
Download test s
Upload test s
Test Bandwidth Speed
of course sat night at a busy time has nothing to do with it, obviously
D/load COS 58 %
U/load COS 82 %
RTT 41 ms
Max Delay 135 ms
Avg Delay 14 ms
Forced Idle 0 %
Route Conc 2.1
Download test s
Upload test s
Message 21 of 23
(593 Views)
Re: MAC delay
13-08-2011 11:23 PM
As i'm you're leaving i couldn't give a monkey's
Message 22 of 23
(593 Views)
Re: MAC delay
05-04-2012 4:52 PM
Just as an update to this thread, we've made a change that means MACs will be supplied within a few hours now rather than 5 days. We're going to trial this and see how it goes before deciding whether to leave it in place, go back to how it was previously or try a different timeframe.
Message 23 of 23
(593 Views)
- « Previous
- 1
- 2
- Next »
