Lower speed after switch from MAAF to Plusnet
robski1
Fixes: 4
I have just switched my broadband and phone package to Plusnet after being with Globalnet / MAAF since 1997.
I have been getting download speeds of 12+ Mb and upload speeds of 0.8Mb with MAAF, but know I am only getting 8.5Mb download, upload is about the same.
Same router & PC and same gateway.
Any suggestions?
Robski1 Sad
Fixes: 76
Re: Lower speed after switch from MAAF to Plusnet
The speed profile just needed updating on the new account, sorry that was missed!
Adam
 Adam Walker
robski1
Fixes: 4
SmileyThanks Adam, I will check it out this evening.
Regards, robski1
robski1
Fixes: 4
Hi Adam, just checked using BTW speed test and all is back normal.
Thanks for your help.
Regards, robski. Smiley
robski1
Fixes: 4
After Adam updated my speed profile all was back to normal for a few days, but now my download speed has dropped back to 5 Mbps from 12+ Mbps. Upload speed remains OK.
My BT profile is showing an IP Profile of 13.03 Mbps, the best it has ever been.
Does my Plusnet profile need checking or could it be something else?  Sad
Fixes: 62
robski1
Fixes: 4
Hi Jim, thanks for your reply.
I have checked via the link you gave and it states:-
Estimated Speed  9Mbps  (Range 7Mb to 11Mb)
Current Line Speed  12.9Mbps
Latest BT Wholesale Test  5.1Mbps  dowmload
IP Profile 13.03 Mbps.
My download speed with MAAF was alwyays 12+ Mbps and it got back to that after Adam updated my Plusnet speed profile, but now it has slipped back. I have had no disconnection other me trying other gateways and doing a router reboot to see if that improved things.
My Voyager 2110 is still synced at 14769 Kbps Down and 1119 Kbps Up.
Any thoughts as to what to do next?
Best Regards,  Robski  Undecided
