Lower speed after switch from MAAF to Plusnet
- Lower speed after switch from MAAF to Plusnet
30-07-2013 9:02 PM
I have just switched my broadband and phone package to Plusnet after being with Globalnet / MAAF since 1997.
I have been getting download speeds of 12+ Mb and upload speeds of 0.8Mb with MAAF, but know I am only getting 8.5Mb download, upload is about the same.
Same router & PC and same gateway.
Any suggestions?
Robski1
Any suggestions?
Robski1
Message 1 of 7
(1,458 Views)
6 REPLIES 6
Re: Lower speed after switch from MAAF to Plusnet
31-07-2013 11:15 AM
Message 2 of 7
(591 Views)
31-07-2013 3:37 PM
:)Thanks Adam, I will check it out this evening.
Regards, robski1
Regards, robski1
Message 3 of 7
(591 Views)
31-07-2013 5:07 PM
Hi Adam, just checked using BTW speed test and all is back normal.
Thanks for your help.
Regards, robski.
Regards, robski.
Message 4 of 7
(591 Views)
04-08-2013 7:37 AM
After Adam updated my speed profile all was back to normal for a few days, but now my download speed has dropped back to 5 Mbps from 12+ Mbps. Upload speed remains OK.
My BT profile is showing an IP Profile of 13.03 Mbps, the best it has ever been.
Does my Plusnet profile need checking or could it be something else?
Message 5 of 7
(591 Views)
04-08-2013 9:16 AM
Message 6 of 7
(591 Views)
04-08-2013 1:16 PM
Hi Jim, thanks for your reply.
I have checked via the link you gave and it states:-
Estimated Speed 9Mbps (Range 7Mb to 11Mb)
Current Line Speed 12.9Mbps
Latest BT Wholesale Test 5.1Mbps dowmload
IP Profile 13.03 Mbps.
My download speed with MAAF was alwyays 12+ Mbps and it got back to that after Adam updated my Plusnet speed profile, but now it has slipped back. I have had no disconnection other me trying other gateways and doing a router reboot to see if that improved things.
My Voyager 2110 is still synced at 14769 Kbps Down and 1119 Kbps Up.
Any thoughts as to what to do next?
Best Regards, Robski
Message 7 of 7
(591 Views)
