Lower SNR
- Lower SNR
Lower SNR
21-03-2016 12:55 PM
My broadband has been rock solid and I want to lower my SNR to around 5. I phoned up Technical Support to ask them, the guy said he had increased the speed of my line but nothing has changed.
How do I lower SNR to around 5 - can I do it myself? Thanks
Message 1 of 6
(1,090 Views)
5 REPLIES 5
Re: Lower SNR
21-03-2016 12:57 PM
The default settings are 9dB, 6dB and 3dB with nothing in between
To change it yourself you will need a router which supports it
What are your present router stats - noise margin, speeds and attenuation
Message 2 of 6
(806 Views)
Re: Lower SNR
21-03-2016 1:17 PM
Quote from: mmac the guy said he had increased the speed of my line but nothing has changed.
I can see that the advisor changed your speed profile from 6300 to 7150, however your sync speed is 7175, so the profile was correct and will likely just change back to 6300 with the next delta report that comes through to us
Your line currently has a target SNR margin of 6dB, however with a meantime between errors of 54 seconds, I wouldn't recommend lowing the SNR Margin any more.
Message 3 of 6
(806 Views)
Re: Lower SNR
21-03-2016 1:41 PM
@'mmac'
The settings are in 3dB steps, which is quite a large jump if you are trying to maximise speed without a large corresponding increase in errors.
What YOU could do, is buy a modem/router which has the "SNR tweak" facility.
That would allow you to override the DLM SNR target algorithm, and try to adjust the figure in smaller than 3dB steps.
By increasing your sync speed (by lowering the target SNR) in small steps AND ensuring the connection is stable over a long time, the DLM learns that your line can go faster, and you may find that you may be able to do another small step a few weeks later - and achieve better results than if you had made that adjustment in one go.
http://www.increasebroadbandspeed.co.uk/SNR-tweak
I have had my ADSL SNR target 'tweaked' for years !
Quote from: Oldjim The default settings are 9dB, 6dB and 3dB with nothing in between
Quote from: mmac How do I lower SNR to around 5 - can I do it myself?
Message 4 of 6
(806 Views)
Re: Lower SNR
21-03-2016 2:21 PM
I managed to tweak it from that link you provided, thanks
OK thanks I will definitely keep that in mind
[Moderator's note by Mike (Mav): Empty quote removed.]
Quote from: HarryB Your line currently has a target SNR margin of 6dB, however with a meantime between errors of 54 seconds, I wouldn't recommend lowing the SNR Margin any more.
Message 5 of 6
(806 Views)
Re: Lower SNR
21-03-2016 2:22 PM
Message 6 of 6
(806 Views)
