Low upstream speed
jms
Low upstream speed
I joined PN 6 weeks ago.  My downstream speed (my.broadbandspeed.co.uk) is about 1887 kbs,
but my upstream speed has dropped to 1kbs (on a good day 2kbs).  Is this normal?
I am running a Macbook Pro laptop with OS X 10.6.8.
The wireless router is the Thomson unit supplied by PN with firmware 8.2.7.8.
The DSL Connection data is attached below.
The BT broadband speed test fails on test 1 upload speed: only 4 threads!: an error has occurred!
I have raised a question (49235196) but without any response.
Any ideas would be gratefully welcomed!
Fixes: 62
Re: Low upstream speed
It might be worth having a read here - I suggest starting at the last post and working backwards - http://community.plus.net/forum/index.php/topic,92497.0.html
jojopillo
HI jms,
Are the tests done wired or wirelessly?
Jojo Smiley
jms
Dear Jojo
BT was via ethernet,  my.broadbandspeed.co.uk  was via wireless.
I've just repeated the latter but via ethernet: D1965kbs, Up 381kbs, which is more
reasonable.  Does this mean that  PN's six-week-old router is u/s for wireless?
Thank you for the prompt response.
jojopillo
Are you getting a different upload speed wirelessly than via ethernet? Smiley
jms
Dear Jojo
The speeds I gave you were via ethernet.  I have repeated them using wireless
getting D1992, Up 31,  Thus the wireless up speed is 12 times slower than the
ethernet one.
jojopillo
HI jms,
I'll see if I can locate a TG585v7 router for you, this will resolve the issue.
Jojo Smiley
jms
Dear Jojo
Thank you for your courteous, efficient and prompt responses,
jms
jojopillo
Hi jms,
You're welcome. I've popped it in 1st class post, so you should get it tomorrow hopefully.
Jojo Smiley
jms
Dear Jojo
New router received, speeds back to "normal".  Thank you to PN staff!
jojopillo
Thanks for letting me know Smiley
