Low upspeed connection
- Low upspeed connection
Re: Low upspeed connection
19-06-2009 1:45 PM
19-06-2009 5:41 PM
The 'extension' socket is connected to the street bt line!
This is my router status page, no more info that I've posted really.
19-06-2009 6:00 PM
19-06-2009 6:24 PM
I've failed 3 times to upload a pic of the socket.
Maybe it'll let me upload this:
19-06-2009 6:27 PM
19-06-2009 6:36 PM
19-06-2009 6:50 PM
Pub time! Not sure if that's good or bad at this point
19-06-2009 7:37 PM
You will need to raise a fault with Plusnet as it looks to be a BT problem
The only thing they will ask is that you check with another filter and another router. Is this possible.
20-06-2009 2:00 PM
I've just gone through the fault checker abd will await the results.
Thanks for all the help. I'll post back when the results are in.
20-06-2009 4:20 PM
We have not been able to complete the checks of your broadband service. This may be the result of a fault in the testing system rather than your service.
We will continue to monitor your fault, please provide more information or further updates on the occurance of your fault. If your fault has not re-occured since our testing, please close the ticket and confirm that you are satisfied that the problem is no longer occuring.
20-06-2009 5:13 PM
What is actually means is that the test didn't complete satisfactorily - I wish they would change the default report
20-06-2009 7:35 PM
23-06-2009 12:02 AM
23-06-2009 8:07 AM
23-06-2009 9:21 AM
