Low upspeed connection
- Low upspeed connection
18-06-2009 6:05 PM
Up Speed 224000
Down Speed 5312000
SNR Margin 13.5
Loop Att. 36.5
Speedtests roughly match 4Mb/0.18Mbit
Anything I can do to improve my upload connection?
Re: Low upspeed connection
18-06-2009 6:09 PM
As you say something is badly wrong.
Have you ever had 448kbps upload sync speed
18-06-2009 6:10 PM
18-06-2009 7:10 PM
I'm at the main socket with no phone plugged in.
18-06-2009 7:33 PM
Draytech Vigor 2600 / 2800
From the web interface http://192.168.1.1
> OnLine Status
You can also telnet into the CLI to get a fair bit more information.
telnet://192.168.1.1
The required command is:
> show adsl
Default username "admin", the password is left blank.
I had that problem which was down to a bad line card in the exchange - Can you hear noise on the line when doing the quiet line test 17070 option 2
18-06-2009 7:46 PM
Dave's Router> show adsl
--------------------------- ATU-R Info (annex A) ----------------------------
Running Mode : G.DMT State : SHOWTIME
DS Actual Rate : 5280000 bps US Actual Rate : 224000 bps
DS maximum Rate : 6496000 bps US maximum Rate : 256000 bps
DS Path Mode : Interleave US Path Mode : Interleave
NE Current Attenuation : 36.5 dB Cur SNR Margin : 13.5 dB
DS actual PSDM(C) : 00000007 US actual PSDM(R) : 000037ab
ADSL Firmware Version : 41e2be2c
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 31.5 dB Far SNR Margin : 7.0 dB
CO ITU Version[0] : 000f414c CO ITU Version[1] : 43420000
DSLAM CHIPSET VENDOR : < Alcatel >
INTL, DSTREAM bytes/depth= 16, symbols/codewords = 0, latency= 0*0.25ms.
, USTREAM bytes/depth= 1, symbols/codewords = 0, latency= 0*0.25ms.
CODE, DSTREAM fast parity bytes= 0, fast codeword= 0.
DSTREAM intl parity bytes= 14, intl codeword= 180.
CODE, USTREAM fast parity bytes= 0, fast codeword= 0.
USTREAM intl parity bytes= 16, intl codeword= 144.
Setting>>
FDQ : Enable, TCM : Enable, EC : Disable, Framing Mode : 3.
Running>>
FDQ : In Use, TCM : Off, EC : Off.
DS : Framing Mode 3, US : Framing Mode 3.
ADI ADSL Firmware Version: 41e2be2c
Dave's Router>
18-06-2009 8:03 PM
Basically your upstream attenuation is far too high and that is killing your upstream speed.
Hearing a faint hiss is unlikely to cause the problem you are seeing.
As Asbo Dog asked can you try the test socket - I think that is a forlorn hope as problems with your internal wiring usually show up in the upstream speed but something is really messing up.
Can you install Routerstats http://www.vwlowen.co.uk/internet/files.htm which will work on your router and see if you can get to this page
18-06-2009 8:50 PM
the router stats page doesn't quite look right either.
Having just looked at where I'm plugged in, I'm remembering things... The test socket is dead, I get no dial tone at all. I recall I found a nearby socket, tried it, and it worked, so that's what I've been using ever since! (moved in and that's how I found it).
18-06-2009 9:17 PM
Now comes the difficult bit.
We are going to need to find the master socket.
Can you find where the BT cable enters the house and what it connects to first.
To get the telnet tab in Routerstats you need to go into configuration (the icon whuch looks like a gear) and select telnet which will give something like this picture.
If you click on the help in Routerstats and search for Draytek it tell you how to set it up.
18-06-2009 9:38 PM
I did as suggested and use the draytek ini file but no change
OK, how do I make photobucket images work?
Oh never mind, they've reduced the pic size so you can't read anything anyway!
18-06-2009 9:56 PM
18-06-2009 10:46 PM
Hmm, it's not very readable for some reason/
19-06-2009 9:25 AM
The bits we will be interested in is System Status and WAN status - at the moment it isn't showing anything because, I assume, you rebooted 1 hr 58 min before
19-06-2009 10:03 AM
19-06-2009 10:11 AM
You say that you're using an extension socket, where does the extension plug into?
