Low speeds
- Re: Low speeds
Low speeds
20-07-2015 9:02 PM
We're currently experiencing extremely low speeds in Putney. Totally dropped off - intermittent - around the 1MB mark at times.
Is this something Plusnet is aware of?
Message 1 of 7
(995 Views)
6 REPLIES 6
Re: Low speeds
20-07-2015 9:06 PM
I think it is something that all plus net customers are experiencing lately. I am sure other can give you a better explanation.
Message 2 of 7
(684 Views)
Re: Low speeds
21-07-2015 10:05 AM
That's a bit of a sweeping statement, intermittent connections are very very unlikely to be common between users across different areas of the country and are usually indicative of something local or a line issue.
Testing now
Testing now
Message 3 of 7
(684 Views)
Re: Low speeds
21-07-2015 10:10 AM
Couple of disconnections, nothing overly concerning.
Profile looks fine:
WBC 160K - 24M Medium delay (INP 1) 6dB Downstream, UC Low delay (INP 0) 6dB Upstream (ADSL2+)
Current line stats:
SYNC: Down: 14661 Up: 1232
ATTN: 25
Errored seconds: 0
Can't see anything obvious from those tests, also we're not seeing an intermittent connection. Are you connection wired or wirelessly?
Profile looks fine:
Current line stats:
ATTN: 25
Errored seconds: 0
Message 4 of 7
(684 Views)
Re: Low speeds
21-07-2015 10:24 AM
Wirelessly,
Three devices struggled last night with basic web navigation, internet banking etc (not at the same time, I should add - tried one, then the other). Almost unusable until it suddenly totally recovered later in the evening, producing great speed - about an hr after I sent original question. Perhaps best description is intermittently good speed as opposed to intermittent connection.
It's happened a lot over the past few days. What are the other potential problems?
James
James
Message 5 of 7
(684 Views)
Re: Low speeds
21-07-2015 10:27 AM
The wireless is my main suspect here.
Do you see any problems when connecting using a cable?
Message 6 of 7
(684 Views)
Re: Low speeds
21-07-2015 1:27 PM
Hmmm,
I'll check if it happens again - I've had problems with speeds in the are in the past, but this was supported up by Plusnet's stats. I'll check with the cable if it happens again & see whether it makes a difference.
Thanks for your help,
James
James
Message 7 of 7
(684 Views)
