Low "current line speed"
coedcwm
According to https://portal.plus.net/my.html?action=data_transfer_speed my current linespeed is 0.2mbps as shown below
Estimated line speed:
8Mb (This may vary between 7Mb and 8Mb) - Checked on 2016-03-05 23:47:11
Current line speed:
0.2 Mb
Is there any reason why this would be the case? Currently my connection is more or less unusable at the moment.
Gel
Seasoned Pro
Fixes: 14
Re: Low "current line speed"
Have you tried toggling router on and off via it's software to see if new connection established is at sensible speed?
coedcwm
Restarting the router doesn't seem to make a difference at all.
Fixes: 62
What are the router stats and also what does the BT speedtest further diagnostics show
coedcwm
The BT Wholesale Speedtest site repeatedly gives me this error: "Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information."
In terms of router stats which ones are relevant?
Fixes: 62
speeds, noise margin and attenuation
coedcwm
Current Rate (Kbps) 448 6912
Max Rate (Kbps) 1168 6976
SNR Margin (dB) 25 12.2
Line Attenuation (dB) 9.5 19.8
Fixes: 62
That tells me several things
You are on 20CN - if you check here http://usertools.plus.net/exchanges/ it won't say "BT have advised that this exchange is enabled for WBC on 21CN"
As such there will be a significant delay in the IP Profile (which you can't see) updating and until that does you are stuck
Given the  high SNR Margin it is likely that there is a fault on the line and this will have caused/contributed to the  low sync speed event which caused the IP Profile to drop to the stupidly low level
Can we take this a bit further
If you dial 17070 option 2 Quiet Line Test - is the line quiet
Is the router connected to the master socket or an extension socket
coedcwm
Yeah the line is quiet and yes the master socket is being used.
Fixes: 62
What about the 21CN question
coedcwm
Yes you're correct: BT have not advised a planned date for WBC on 21CN
Fixes: 62
in which case I would suggest raising a fault here https://faults.plus.net and see what comes back - they will require you to connect the router via the test socket using a filter - this gives details of how to do it if you need them http://community.plus.net/forum/index.php/topic,143835.0.html
coedcwm
My current line speed value is now showing as 7.15 Mb once more, yet my internet speed have not yet been restored, is it to be expected that my previous speed will return soon?
Fixes: 62
it will but you will need to do the following
Go into the router interface and click on disconnect then after about 20 secs click on connect
This doesn't resync the router just drops the PPP session
coedcwm
Doesn't seem to make a difference to the speed currently.
