Low profile
tonycollinet
Low profile
Just noticed router was syning at 18db snr and 8mb/s
Rebooted and it's back to 6db, and 17mb/s - but the plusnet profile is still at 8. Will this change automatically? (if so, when) Or will I have to wait for plusnet to correct it?
9 REPLIES 9
Fixes: 160
Re: Low profile
It could rake an hour or two depending on when BTOR ships the delta and the update script runs.
The update script should drop the PPP session, though sometimes you need to do it manually.
tonycollinet
Re: Low profile
tonycollinet
Re: Low profile
And, there it is. Smiley
tonycollinet
Re: Low profile
OK - profile has updated on "high speed broadband" but I'm still only getting download speeds (and speedtests) of < 7Mb/s
Router conected at 18011
Current line speed:
15.5 Mb
Any ideas? Or do I need to wait for something else to update?
Fixes: 160
Re: Low profile
Tony,
Is that wired or wifi connected?
Kevin
tonycollinet
Re: Low profile
wired. and the speed test is rock steady each time - As though being throttled. Going to go and do a bt test now.
EDIT:
. Best Effort Test:  -provides background information.
Download  Speed
6.57 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 6.57 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 15.89 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.69 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.69Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Router stats.
Modulation : ADSL2+
Annex Mode : Annex A/L
Line State : up
Lan Tx : 204612129
Lan Rx : 128748340
ADSL Tx : 2381328
ADSL Rx : 35963540
CRC Down : 0
CRC Up : 3592
FEC Down : 0
FEC Up : 3628
HEC Down : 1625
HEC Up : 0
SNR Up : 7.0
SNR Down : 6.1
Line Attenuation Up : 9.9
Line Attenuation Down : 15.0
Data Rate Up : 1064
Data Rate Down : 18011
ejs
Aspiring Hero
Fixes: 25
Re: Low profile
Did the PPP session disconnect when the profile changed? If not, then you just need to disconnect and re-connect via your router's web interface.
tonycollinet
Re: Low profile
That could be it. Although I've not found a way to drop the PPP session without rebooting the router. (It's an asus DSL55U)
EDIT:
OK - managed to force it by changing the username, then back again.
That's fixed it, thanks.
chenks76
All Star
Fixes: 12
Re: Low profile
Quote from: Townman
don't bank on the update script dropping the PPP though.
last 2 times my profile was updated i had to drop PPP myself.
