Low download speed
- Re: Low download speed
Low download speed
23-06-2011 7:55 PM
Pretty newish to Plusnet and have been checking my download speed which is somewhere between 1.2 and 1.5 mbits. I am sure when i first joined that i was told i should hit somewhere up to 5 mbits. Is my speed actually low or is this what i should expect?
23-06-2011 8:40 PM
We can then try and understand why your speed may be low.
24-06-2011 8:05 AM
24-06-2011 1:43 PM
Welcome Are you using any extension cables/sockets at all. Do you have a test socket behind your faceplate?
Jojo
24-06-2011 2:03 PM
Yes, that's a good start. That speed isn't good for the attenuation of your line and the error counts are very high.
Looks like Jojo's on the case though...
24-06-2011 2:12 PM
Thanks for the reply. I am not using any extension cables. I have connected the router into the test socket on the BT master and still only get around 1.2 - 1.5 Mbits.
24-06-2011 3:30 PM
when you connect to the test socket you won't see any difference in your speed but what you would see is a different sync rate. If it's still in the test socket I can run some checks, so let me know.
Jojo
26-06-2011 7:44 PM
Sorry i didn't pick your reply up till late. The router is now connected to the test socket so you should be able to do the tests
27-06-2011 2:56 PM
I'm going to get the SNR lowered now you're in the test socket. I'll let you know once it's taken effect how it's looking.
Jojo
27-06-2011 3:22 PM
27-06-2011 3:35 PM
27-06-2011 4:07 PM
Can i take the router out of the test socket now?
27-06-2011 4:10 PM
It may be that not being in the test socket was causing the issue. I'd advise you to leave it there a few days so we can be sure whether that is the problem or not.
Jojo
27-06-2011 4:12 PM
27-06-2011 4:15 PM
