Low Throughput, High sync speed, Nil Output Power
- Low Throughput, High sync speed, Nil Output Power
Re: Low Throughput, High sync speed, Nil Output Power
21-07-2012 10:22 AM
21-07-2012 10:33 AM
A normal BT Openreach engineer checks for line faults with his Hawk Tester as well as other equipment and is quite capable of dealing with faults of that nature, along with many other type of line fault. That is their job. I suggest you have a chat with some, you may learn something.
An SFI engineer is only needed with more complex faults and usually the ones that an normal OR eng cannot readily fix.
21-07-2012 10:38 AM
So have BT Retail arranged for an OR engineer to find and fix the fault? (presumably given you a date/time slot?)
21-07-2012 11:48 AM
Yes, I have spoken with a BT telephone engineer recently, that is how I know.
I suggest you go and speak to a BT telephone engineer and ask him why he isn't allowed to deal with broadband faults.
In the past yes, they probably would of done. In the modern day, no they dont as they have different engineers dedicated for different tasks.
21-07-2012 12:03 PM
Keep your fingers crossed that the BB issue is now FIXED!!!
21-07-2012 12:03 PM
This is/was NOT a broadband fault - this is/was a PHONE fault. You should go on some engineering courses and learn a few things.
21-07-2012 12:08 PM
adie:quote
21-07-2012 12:11 PM
21-07-2012 12:12 PM
21-07-2012 2:19 PM
BT Retail do not have any contractual relationship with Plusnet for the customer's line so sadly it falls to the customer to report the line problem to BT Retail and get them to carry out a test. Getting them to do that when the telephone appears to be OK can be difficult, but it is surprising what phone-related symptoms become apparent when one thinks about it.
However hopefully the line problem has now been fixed and the broadband service with it.
21-07-2012 4:11 PM
Looking at my Router Stat then my sync speed is now down to 16,048 and the noise is at 6.5
Thank you guys for all your words and comments, it's been a learning curve for me!
21-07-2012 4:43 PM
21-07-2012 4:44 PM
7Mb (Accurate to within +/- 1Mbit) - Checked on 2012-06-18 18:39:11
Current line speed:
15.2 Mb
21-07-2012 5:04 PM
21-07-2012 5:18 PM
