Low Speed
skimarqueshc
Re: Low Speed
Gandalf, I've raised the fault, many thanks
OskarPapa
Fixes: 65
Re: Low Speed
Hi @skimarqueshc,
Thanks for the update.
I can see that our faults team located the issue and have identified it as being a mismatch between your actual line profile and our systems.
You may have noticed a drop in connection of a few minutes while the changes were made.
Are you noticing a difference your end?
skimarqueshc
Re: Low Speed
The SNR is the same and my maximum data rate is still 2.1mb, I have had it upto 3mb before, do I need to reboot my router
skimarqueshc
Re: Low Speed
I have checked the router this morning and the SNR for the downstream is 14.9 and my download speed is at 1026kbps
It seems the connection last dropped about 3 hours ago
Fixes: 1,600
Re: Low Speed
I think the next step is to arrange an engineer visit for further investigation.
If you can reply to this ticket with your availability, giving us a nudge over here once you've done so we'll be happy to book the appointment in as soon as possible for you.
skimarqueshc
Re: Low Speed
I've dropped a reply
LaurenB
Fixes: 131
Re: Low Speed
Hi @skimarqueshc, I have responded on the ticket for you.
 Lauren Barry
skimarqueshc
Re: Low Speed
Lauren just before you updated the ticket your colleague Chris updated it and did something with the line which has improved the speed and it seems stable too, I was told to leave the router on for 10 days for the stabilisation period  so I'll monitor over the next week.
RandallFlagg
Fixes: 75
Re: Low Speed
Thanks for the update, @skimarqueshc
Let us know how you get on.
Best wishes
Dave
