Lovefilm oddity
- Lovefilm oddity
Lovefilm oddity
09-03-2011 9:31 AM
If youg o to http://www.lovefilm.com/film/Due-Date/135153/ or any other lovefilm page, do you get a continuous 'loading' caption showing at the top of the image where the trailer should be playing? It is odd, I am not sure if this a PN problem or problem with my laptop. I have hopped gateways to see if that helps, it does not.
What do others get? I will be in my office later on a 20Mb fibre connection so will see what gives then too.
3Mb FTTC
3Mb FTTC
Message 1 of 4
(938 Views)
3 REPLIES 3
Re: Lovefilm oddity
09-03-2011 10:44 AM
Now at my office and get the same problem. Likely not a PN issue then.
3Mb FTTC
3Mb FTTC
Message 2 of 4
(387 Views)
Re: Lovefilm oddity
09-03-2011 11:42 AM
It's working fine here
Message 3 of 4
(387 Views)
Re: Lovefilm oddity
09-03-2011 1:04 PM
Thanks. Looks like its an AdBlock Plus problem, if I turn off ABP, the problem goes away. Hmm.
3Mb FTTC
3Mb FTTC
Message 4 of 4
(387 Views)
