Lots of disconnects, speed plummeting
Ngee
Line had been pretty stable for some time, but over the last few days I've been getting many, many disconnects, and speed has dropped from the heady heights of 4mb to under 2mb.
  Upstream Downstream
Current Rate (Kbps) 984 1880
Max Rate (Kbps) 984 1992
SNR Margin (dB) 6 15.7
Line Attenuation (dB) 29.1 50.6
Errors (Pkts) 0 0
Download speed achieved during the test was - 1.6 Mbps
For your connection, the acceptable range of speeds
is 0.8 Mbps-2 Mbps.
IP Profile for your line is - 1.66 Mbps
I suspect RADIIUS is not going to look pretty - can anyone from PN have a look and assist?
Ta
SpendLessTime
Aspiring Hero
Fixes: 79
Re: Lots of disconnects, speed plummeting
Hi @Ngee
You may wish to edit your post and remove your username. Plusnet staff can ask for a PM with those details.
Ngee
Good point... edited... thanks
Fixes: 20
Hi Ngee,
I am sorry to see this. Can you run through these checks for me please & let me know how you get on after http://www.plus.net/support/broadband/bbfaults/
 Ben Babinski
Fixes: 165
Your RADIUS graph doesn't look the best:
 Chris Parr
 Plusnet Staff
Ngee
That's about what I expected.  I'm on a long bit of copper, so the occasional disconnect is "normal" and doesn't really cause an issue. But clear something has happened recently that's had a significant impact.
Ngee
So...
BTWholesale speedcheck still reports 1.7mb line, although IP profile looks about right for that speed.
Phone line works - no discernable noise/crackle.
Microfilters all ok, and swapped out to check.
Already plugged into master socket in any case.
No facility to try a different router at this time.
Ngee
Interestingly, I was completely unable to connect at all yesterday, coinciding with the heavy rain!
The route was stuck in a cycle of initialising, connecting, dropping.
This morning, as presumably everything is dry again, it's reconnected.
