Lots of DC's, can't use faults.plus.net
- Lots of DC's, can't use faults.plus.net
05-10-2010 4:04 PM
I have been disconnecting quite frequently recently, it was bad over the weekend but I switched firmware on my Cisco and it seems to have gotten better but I'm still disconnecting a fair bit which has resulted in my speed dropping from a stable 8mb to 6mb. I try to go to faults.plus.net but that results in...
We were unable to complete your requested action. This may be the result of a temporary fault.
Please try again in a few minutes.
So I can't progress in that manner.
My modem stats and such:
My attenuation is usually a solid 29db and my SNR 9db. I switched from my Cisco to a Netgear and that too reported the same attenuation/snr as well as the low connection speed.
I did have a *lot* of disconnections a couple of bit ago but that was due to an idle setting on my Buffalo (which I'm not using). My Cisco "activations" is at 4 which means it's reconnected 4 times since I turned it on yesterday.
Any ideas on what to do? I can't raise a fault at faults.plus.net (no idea why) and if I keep disconnecting my speed won't stabilise.
Quote ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x03 0x2
Vendor ID: 'STMI' 'TSTC'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x0F 0xB5
Chip ID: C196 (0)
DFE BOM: DFE3.0 Annex A (1)
Capacity Used: 99% 48%
Noise Margin: 14.5 dB 26.0 dB
Output Power: 19.5 dBm 12.5 dBm
Attenuation: 32.0 dB 14.0 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0x22
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 8284 (0 spurious)
PHY Access Err: 0
Activations: 4
Interleave Fast Interleave Fast
Speed (kbps): 6240 0 448 0
Cells: 3090116 0 4130265 0
Reed-Solomon EC: 6 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Total BER: 0E-0 0E-0
Leakage Average BER: 0E-0 0E-0
Bitswap: enabled enabled
Bitswap success: 0 0
Bitswap failure: 0 0
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 3 5 6 6 7 7 7 7 8
010: 8 8 8 7 7 7 7 7 7 7 6 6 4 4 3 0
020: 0 0 0 0 0 B B C C C B B C B C B
030: C B B B B B B B B B B B B A A B
040: 0 A A B A A A A A A 2 A A A A A
050: A A A A A A 9 9 A 9 9 9 9 9 9 9
060: 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9
070: 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9
080: 8 9 8 8 9 8 8 8 8 8 8 8 8 8 8 8
090: 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
0A0: 8 8 8 8 8 8 8 8 8 7 8 8 8 8 8 8
0B0: 8 8 8 8 8 8 8 8 7 7 8 8 8 8 7 7
0C0: 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7
0D0: 7 7 7 5 7 7 7 7 7 7 7 7 7 7 7 7
0E0: 7 7 7 6 7 7 7 6 6 6 6 7 6 7 7 6
0F0: 6 6 6 6 6 6 6 6 6 6 6 5 4 4 5 6
Message 1 of 1
(452 Views)
