Lost internet 3hrs ago can't report it
- Re: Lost internet 3hrs ago can't report it
04-12-2021 8:52 PM
04-12-2021 8:56 PM
@stys0n844 Welcome to the forum.
You can report a fault at https://faults.plus.net.
04-12-2021 9:18 PM
04-12-2021 9:53 PM
@stys0n844 How does your Broadband work if you don't have a landline, perhaps you mean you don't know your landline number or you have no phone connected to it.
04-12-2021 9:55 PM
04-12-2021 10:08 PM
04-12-2021 10:20 PM
But ADSL broadband is, by definition, provided over a landline. 🤔
FTTC 40/10 Billion 8800NL
BT technician (Retired)
04-12-2021 10:35 PM
04-12-2021 10:41 PM
You are on fibre to the cabinet, not fibre to the premises. If you plug a phone in it will work. If you don’t know the number ring 17070 and you will have a recorded message telling you the number.
This is a community forum. For it to be reported through here you will have to wait until a Plusnet staffer comes along.
04-12-2021 10:48 PM
04-12-2021 11:58 PM
Well at least you've got it reported.
If you have no internet, then how have you been reporting it on here?
Are you using a mobile phone with mobile phone data? If so I would turn data tethering on which may help, if your computer is able to connect to a wireless network then it will at least give you a working connection in the meantime whilst you wait for your issue to be fixed.
I did the same when my Branson Media connection went down, I am lucky that an EE mast is in the street next to mine so I get good mobile reception.
Not ideal but will get you out of trouble, just keep within your data allowance. I get 25Gb, which is quite a lot to be fair.
05-12-2021 12:18 AM
05-12-2021 9:46 AM
@stys0n844 wrote:
I've finally been able to log it. Hopefully something will start be done. I have to say it's alot easier to report line issues on BT.
That’ll be partly due to BT being more expensive.
05-12-2021 9:47 AM
Then this topic will tell you what to do.
05-12-2021 5:26 PM
