Lost connection
sully666
Lost connection
Just out of my training period and have lost connection for the second consecutive evening in a row. Son is very annoyed as it kicked him out of his X-Box session.
Here are my line stats  after reconnection
Link Information
Uptime: 0 days, 0:01:51
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.106 / 19.724
Data Transferred (Sent/Received) [MB/MB]: 1,04 / 14,58
Output Power (Up/Down) [dBm]: 12,2 / 20,9
Line Attenuation (Up/Down) [dB]: 5,6 / 11,0
SN Margin (Up/Down) [dB]: 6,2 / 3,2
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Link (Remote): -
FEC Errors (Up/Down): 1 / 69.378
CRC Errors (Up/Down): 2 / 0
HEC Errors (Up/Down): 2 / 0
Never had these sort of issues with BE and my tg587n v2  Embarrassed
apjashley1
Re: Lost connection
Can you post the router's log - under the gateway page - as this will help us work out why your connection dropped.
sully666
Re: Lost connection
Just lost connection AGAIN  Angry  Took half an hour to reconnect.  Had only been asked yesterday by a friend if I could recommend PlusNet as a replacement for his BE connection.  At this moment in time it would be a resounding no.
Recorded Events
Time
Message
Info  Apr 2 23:08:26 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info  Apr 2 22:07:38 SNTP Synchronised to server: 212.159.6.10
Error  Apr 2 22:07:38 SNTP Systemtime update: time setting 00:05:50 > new time setting: 22:07:38
Error  Jan 1 00:03:35 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 65.55.42.131 Dst ip: 80.229.225.85 Type: Destination Unreachable Code: Port Unreacheable
Info  Jan 1 00:03:34 CONFIGURATION saved by TR69
Info  Jan 1 00:02:29 FIREWALL event (1 of 6): deleted rules
Warning  Jan 1 00:02:28 PPP link up (Internet) [*.*.*.*]
Info  Jan 1 00:02:28 PPP CHAP Chap receive success : authentication ok
Info  Jan 1 00:02:27 PPP CHAP Receive challenge (rhost = ptn-ag02)
Info  Jan 1 00:02:27 PPP CHAP Receive challenge (rhost = bras-red1.sf)
Info  Jan 1 00:02:20 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info  Jan 1 00:01:17 xDSL linestate up (ITU-T G.992.5; downstream: 19764 kbit/s, upstream: 1134 kbit/s; output Power Down: 21.0 dBm, Up: 12.2 dBm; line Attenuation Down: 11.0 dB, Up: 5.6 dB; snr Margin Down: 3.1 dB, Up: 5.0 dB)
Error  Jan 1 00:01:09 [ANTI_SPOOFD] (err) llist_getobject_at for ENV.ANTI_SPOOFD's value failed
Info  Jan 1 00:00:49 xDSL linestate down
Warning  Jan 1 00:00:38 DHCS server up
Info  Jan 1 00:00:38 FIREWALL event (1 of 1): deleted rules
Info  Jan 1 00:00:38 FIREWALL level changed to Standard.
Error  Jan 1 00:00:36 UPnP framework enabled
Info  Jan 1 00:00:36 FIREWALL event (1 of 1): modified rules
Info  Jan 1 00:00:36 FIREWALL event (1 of 1): created rules
Error  Jan 1 00:00:30 UPnP framework disabled
Error  Jan 1 00:00:28 UPnP framework disabled
Error  Jan 1 00:00:26 UPnP framework disabled
Warning  Jan 1 00:00:14 KERNEL Warm restart
Info  Apr 2 23:01:37 SYSTEM timed reboot triggered by timeout
Error  Apr 2 23:01:26 UPnP framework disabled
Error  Apr 2 23:01:24 UPnP framework disabled
Info  Apr 2 23:00:50 FIREWALL event (1 of 1): modified rules
Info  Apr 2 23:00:50 FIREWALL event (1 of 1): created rules
Warning  Apr 2 23:00:50 DHCS server went down
Error  Apr 2 23:00:50 UPnP framework disabled
Info  Apr 2 23:00:50 CONFIGURATION mbus igd sync successfull
Info  Apr 2 23:00:48 FIREWALL event (1 of 1): deleted rules
Info  Apr 2 23:00:47 CONFIGURATION mbus atomic sync successful
Info  Apr 2 22:58:17 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info  Apr 2 22:53:45 LOGIN User admin tried to login on [HTTP] (from 192.168.1.64)
Info  Apr 2 22:52:44 LOGIN User admin tried to login on [HTTP] (from 192.168.1.64)
Info  Apr 2 22:51:56 xDSL linestate down
Info  Apr 2 22:49:39 FIREWALL event (1 of 16): modified rules
Info  Apr 2 22:49:39 FIREWALL event (1 of 26): created rules
Warning  Apr 2 22:49:39 PPP link down (Internet) [*.*.*.*]
Info  Apr 2 22:49:04 LOGIN wireless station [d8:5d:4c:e9:ef:5d] can't get authorized.
sully666
Re: Lost connection
Anyone any ideas why the disconnects have staretd happening?
Re: Lost connection
It could be your noise margin is too low - but you obviously live close to the exchange as your line attenuation is really good.
Are you plugged into the Master Socket? Do you have an extensions?
leight
Re: Lost connection
Quote from: sully666
That looks quite high to me.
apjashley1
Re: Lost connection
Looking at your router's log, the whole machine restarted (rather than you losing broadband connection).
sully666
Re: Lost connection
Yes, I restarted my machine as I have often found it helps with getting reconnected.  Router is into master socket and connected via the LAN port.  Never had issues like this while with BE. Router was often up for MONTHS between disconnects.
Very disappointed  Undecided
sully666
Re: Lost connection
Anyone? Or do I wait with bated breath for tonights disconnect now  Sad
Fixes: 163
Re: Lost connection
I'd strongly advise opening a fault ticket if you're getting disconnects. Without doing so our support team aren't going to know you're got a problem and therefore can't help to fix it.
https://faults.plus.net
 Chris Parr
 Plusnet Staff
Re: Lost connection
It's probably worth raising it as a fault via http://faults.plus.net and running through that process.
It could be an error on your line.
sully666
Re: Lost connection
Fault raised.  Here's hoping it can be sorted  Sad
sully666
Re: Lost connection
Fault report now appears to have gone from my member centre page without receiving a reply  Shocked
Is this normal?
Re: Lost connection
sully666
Re: Lost connection
Found it and awaiting reply
