Lost all my speed - SNR sky high
- Lost all my speed - SNR sky high
- « Previous
- 1
- 2
- Next »
Re: Lost all my speed - SNR sky high
13-03-2013 1:41 PM
13-03-2013 5:00 PM
Sorry about this.
13-03-2013 7:01 PM
19-03-2013 3:46 PM
Please can you have a go at this for me?
19-03-2013 3:53 PM
19-03-2013 6:53 PM
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 03:08:44
Downstream: 16.13 Mbps
Upstream: 828 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 5.4 dB / 12.1 dB
Line attenuation (Down/Up): 20.4 dB / 10.6 dB
Output power (Down/Up): 20.2 dBm / 12.6 dBm
FEC Events (Down/Up): 28553 / 20615
CRC Events (Down/Up): 16 / 1576
HEC Events (Down/Up): 136 / 79
Error Seconds (Local/Remote): 12 / 96
19-03-2013 7:00 PM
19-03-2013 7:04 PM
19-03-2013 8:03 PM
20-03-2013 8:32 AM
ADSL Line Status
Connection time: 0 days, 13:26:46
Downstream: 16.05 Mbps
Upstream: 828 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Noise margin (Down/Up): 6.4 dB / 12.2 dB
Line attenuation (Down/Up): 20.3 dB / 10.7 dB
Output power (Down/Up): 20.3 dBm / 12.6 dBm
FEC Events (Down/Up): 91459 / 21432
CRC Events (Down/Up): 67 / 1880
HEC Events (Down/Up): 1122 / 87
20-03-2013 1:13 PM
20-03-2013 1:51 PM
Really sorry this is taking so long. I'm currently waiting for our suppliers systems to get back on their feet so I can get some work done on this for you. I'll update you once I've managed to get that sorted for you.
26-03-2013 1:43 PM
With the only connections in my master socket being 2 sets of blue pairs (on top of one another) in terminals 2+5, my extensions still work.
Should I be re-wiring this to improve my connection? I assume if Openreach came to take a look I'd be hit with a £60 bill, as it's my wiring that's at fault, but they should have done it properly in the first place!
UPDATE: I pulled out one of the two pairs, disconnecting the extensions, but it gave me an extra 1MB instantly on my download speed
- « Previous
- 1
- 2
- Next »
