Lost all my speed - SNR sky high
- Re: Lost all my speed - SNR sky high
05-03-2013 11:38 AM
What can I do to fix it?
05-03-2013 12:36 PM
I've been looking after your Fault Ticket. When your SNR is down at 3db your line starts to error, a lot. Your downstream SNR is currently at 5.7db (6db is the target). The SNR is likely to be fluctuating due to the errors. Can you confirm that you are still connected into your Test Socket?
05-03-2013 12:43 PM
05-03-2013 3:08 PM
05-03-2013 6:54 PM
06-03-2013 9:36 AM
If you start to notice any drops on your line, please let me know.
06-03-2013 11:31 AM
06-03-2013 12:59 PM
06-03-2013 1:08 PM
06-03-2013 3:55 PM
Not a lot we can do while the current SNR reset is still going through, but given your line quality (green, which is good) it should sort itself out over the next couple of days automatically anyway.
07-03-2013 12:48 PM
Any chance I can ask for the manual SNR targets to be removed, and a full SNR reset?
07-03-2013 1:02 PM
11-03-2013 4:39 AM
Thanks to help from Anotherone I've got rid of the crackle on my line that's been there since it was installed.
Can the DLM be completely reset?
11-03-2013 9:20 AM
I'll make sure this gets sorted on Wednesday for you.
13-03-2013 1:32 PM
