Lost Wifi Connection
- Lost Wifi Connection
13-11-2012 6:03 PM
For some reason my ipod touch will not connect to Plusnet wifi it keeps asking for the password,I used the WEP password on the underside of the router but it does not accept it now I have tried my login password but no such luck I hope can help otherwise it's back to the Apple shop.
Message 1 of 3
(991 Views)
2 REPLIES 2
Re: Lost Wifi Connection
13-11-2012 8:50 PM
The password is case sensitive. Also make sure you're trying to connect to the right SSID, a neighbour might be using PlusNet too.
That's RPM to you!!
Message 2 of 3
(478 Views)
14-11-2012 5:56 PM
I think I have solved the problem I switched my router off and switched on again and my ipod touch as responded to my password, it seems the wifi logo as changed to steps on the taskbar before it was a screen
Message 3 of 3
(478 Views)
