Lost Connection
- Re: Lost Connection
Lost Connection
03-10-2013 4:54 PM
Hi ,
i have just lost connection say 10 minutes ago and my speed just dropped big time and my ip profile fell from 14mb to 8mb is this normal i have had a stable connection apart from 2 nights one of those i was upgrading the firmware (tg582n 10.2.2.B ) .
Message 1 of 8
(1,249 Views)
7 REPLIES 7
Re: Lost Connection
03-10-2013 5:14 PM
It looks like a period of very short connections has caused the IP profile to lower:
<img src="http://community.plus.net/visualradius/generated/image13808167323940.png"/>
Are these due to anything you were aware of or doing? if not we'd just need to make sure the connection is stable first and we can put an SNR reset through for you.
Adam
Adam
Message 2 of 8
(655 Views)
Re: Lost Connection
03-10-2013 5:20 PM
Hi adam,
Yes monday i was trying out a new router but wasnt keeping connection very well as you can see so decided to stick with the tg582n so on tuesday night upgraded the firmware on it but had trouble but eventually manage to get it up and running apart from that have had no other problems
Thanks.
Thanks.
Message 3 of 8
(655 Views)
Re: Lost Connection
03-10-2013 5:30 PM
OK, in that case I'd keep an eye on things over the next couple of days, if the connection remains stable I can process the SNR reset, that should bring the speed profile back in line otherwise that would be a good time to raise a fault: http://faults.plus.net
Message 4 of 8
(655 Views)
Re: Lost Connection
03-10-2013 5:46 PM
ok thank you adam i may get my fibre upgradre yet been trying to convince the wife we should get it and another problem pops up lol
Message 5 of 8
(655 Views)
Re: Lost Connection
03-10-2013 11:17 PM
hi,
my speed has dropped yet again twice today i could understand if i was loosing connection all the time but am not just down another test
1. Best Effort Test: -provides background information.
Download Speed
7.96 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speed achieved during the test was - 7.96 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 8.11 Mbps
Am sure yesterday acceptable range was 7 - 16 and my ip profile was 14
Download Speed
7.96 Mbps
0 Mbps 7.15 Mbps
Message 6 of 8
(655 Views)
Re: Lost Connection
04-10-2013 1:32 PM
Should i raise a fault because i dont want to waste peoples time looking for something thats not there because iam 99% sure its not a fault
Thank you.......
Thank you.......
Message 7 of 8
(655 Views)
Re: Lost Connection
07-10-2013 10:04 AM
I'd certainly suggest running through our faults wiazrd - http://faults.plus.net so we can take a closer look at what's going on.
Message 8 of 8
(655 Views)
