Loss of realistic connection
- Loss of realistic connection
19-05-2014 4:59 PM
Suddenly my connection has gone to this
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
0.27 Mbps
0 Mbps 2 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.27 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :1.86 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 1.5 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
Download Speed
0.27 Mbps
0 Mbps 2 Mbps
Message 1 of 5
(703 Views)
4 REPLIES 4
Re: Loss of realistic connection
19-05-2014 5:07 PM
Hi stathe,
Are those results whilst connected with an Ethernet Cable?
Message 2 of 5
(441 Views)
19-05-2014 5:21 PM
Yes they are but it seems fine now, though unable to run that same test again as it wants me to change my router settings and am afraid to do that, so will forgo the second part of the test and see what happens
Message 3 of 5
(441 Views)
20-05-2014 9:47 AM
If you're still experiencing any issues, stathe please raise a fault here: http://faults.plus.net
Our faults team can then investigate this for you and provide you with any updates.
Message 4 of 5
(441 Views)
20-05-2014 11:38 AM
Seems well at the moment after big thunder storm last night, when I switched all off when we had a series of power failures Thank You
Message 5 of 5
(441 Views)
