Loss of connection
reserved19
Loss of connection
Several times a day I lose connection.When I check connectivity via the router I get the following result. Turning the router off/on usually resolves the problem. Any suggestions please?
Test Results
Test Succeeded DSL
Test Succeeded ATM
Test Succeeded PPP
Test Succeeded IP
Test Failed Internet
Disabled/Not OKConnectivity to Gateway (172.16.10.30)
Fixes: 26
Re: Loss of connection
That's a BT routing issue. Suggest you raise a BB fault report or use chat. Be sure to mention the IP gateway address ... that will avoid all of the synch and line stability considerations which would be red herrings here.
reserved19
Thanks for your reply. I did try chat earlier but the Q was very long!
Hopefully a rep will spot this post.
reserved19
Just tried the online chat and just got referred to the fault checker which just returned a fault message!!
Tags (2)
Seasoned Champion
Fixes: 9
@reserved19 @Townman
I think the big red 'X' is a red herring - I get exactly the same response, albeit a different IP, if I do a connectivity check, and I've been continuously connected for over a fortnight.
reserved19
You are right John, I have just tried it and still get the when the connection is working!
More confused than ever!!
Fixes: 166
 We're seen 3 disconnections over the last 7 days, are you on wired or wireless internally as this may not be the connection dropping out but the wifi internally.
 Chris Parr
 Plusnet Staff
reserved19
Hi Chris
This does happen on my laptop, smartphone and other smartphones using wifi so could it be the router?
