Loss of connection
- Loss of connection
Re: Loss of connection
12-09-2015 12:04 PM
12-09-2015 12:17 PM
Anyhow it's good to confirm that there is no end user change here and good to see that your exchange equipment is capable if making the choice - some do not do this.
13-09-2015 8:25 PM
Just an update on router stats, taken a few moments ago, showing little or no change except a gradual increase in the errors count.
Am I right in saying that you had no reply from @CRT regarding the reset and uncapping as I'm at present struggling to get 3Mb even with the bandwidth now reading 4.818.
Link Information
Uptime: 2 days, 4:14:43
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 440 / 4,818
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 351.00
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 28.5 / 48.0
SN Margin (Up/Down) [dB]: 14.0 / 12.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4,294,967,264 / 27,398
CRC Errors (Up/Down): 4,294,967,264 / 243
HEC Errors (Up/Down): 0 / 218
14-09-2015 9:19 AM
This stability looks promising for you though.
14-09-2015 9:36 AM
Not sure whether it has anything to do with the current problem but this morning my phone line is completely dead. All lights are on so it's not a power disconnection just a dead line.
Any ideas, please?
14-09-2015 9:59 AM
14-09-2015 10:09 AM
These are the router stats taken a minute or two ago. FEC & CRC errors gone but up/down speeds decreased. Hopefully these will increase in time.
Link Information
Uptime: 0 days, 0:00:17
Bandwidth (Up/Down) [kbps/kbps]: 384 / 4,694
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 29.0 / 48.5
SN Margin (Up/Down) [dB]: 4.5 / 12.5
Loss of Framing (Local/Remote): 33 / 0
Loss of Signal (Local/Remote): 3 / 0
Error Seconds (Local/Remote): 4 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 224 / 0
14-09-2015 3:51 PM
Link Information
Uptime: 0 days, 2:50:44
Bandwidth (Up/Down) [kbps/kbps]: 68 / 4,121
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 18.00
Output Power (Up/Down) [dBm]: 11.5 / 0.0
Line Attenuation (Up/Down) [dB]: 30.0 / 49.5
SN Margin (Up/Down) [dB]: 17.5 / 15.0
Loss of Framing (Local/Remote): 67 / 0
Loss of Signal (Local/Remote): 6 / 0
Error Seconds (Local/Remote): 7 / 0
FEC Errors (Up/Down): 4,294,967,220 / 5,269
CRC Errors (Up/Down): 4,294,967,220 / 52
HEC Errors (Up/Down): 0 / 48
14-09-2015 3:58 PM
This is how the wiring should be...
Master socket --> Filter --> phone extension wire --> socket --> phone
\--> Router cable --> Router --> 10m Ethernet cable --> Computer
The "router / computer" connection should not be connected over the phone extension cable.
There is some risk that the phone extension cable is picking up some interference as it is not twisted pair. I'm hoping that we do not need to deal with that to fix this. There was a massive improvement over recent days - need to identify what has 'stuffed' it!
14-09-2015 4:36 PM
Link Information
Uptime: 0 days, 0:00:51
Bandwidth (Up/Down) [kbps/kbps]: 440 / 4,705
SN Margin (Up/Down) [dB]: 18.0 / 12.5
Loss of Framing (Local/Remote): 35 / 0
Error Seconds (Local/Remote): 3 / 0
HEC Errors (Up/Down): 7 / 0
14-09-2015 5:03 PM
1. Best Effort Test: -provides background information.
Download Speed
4.14 Mbps
0 Mbps 4 Mbps
Max Achievable Speed
Download speed achieved during the test was - 4.14 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 4.15 Mbps
Upload Speed
0.33 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.33Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
That's the best I've had for many months. Can I hope it will last?
Again, Townman, many thanks for your continued tolerance of my ineptitude and the kind assistance you have given in hopefully resolving this problem.
14-09-2015 5:21 PM
Yes you can. Your internal wiring has been making a rather bad contribution to the internet's performance. Iffy wiring and the filter in the wrong place will not have helped.
For clarification - how was the router connected at the master socket if the filter was on the end of the extension wire?
The router stats are better all round, though we need to watch US framing loss and errors.
Need CTR to reset this line for you....
14-09-2015 5:36 PM
Link Information
Uptime: 0 days, 0:14:17
Bandwidth (Up/Down) [kbps/kbps]: 424 / 4,448
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 1.00
Line Attenuation (Up/Down) [dB]: 29.0 / 49.0
SN Margin (Up/Down) [dB]: 13.0 / 13.0
Loss of Framing (Local/Remote): 59 / 0
Loss of Signal (Local/Remote): 5 / 0
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): 4,294,967,083 / 14
CRC Errors (Up/Down): 4,294,967,083 / 0
HEC Errors (Up/Down): 0 / 0
This happened after I made a local call to a neighbour and lost my internet connection. Having restored the connection I made another call but this time with no loss.
The router was connected with an ADSL/ phone adapter directly into the test socket.
14-09-2015 8:52 PM
14-09-2015 9:35 PM
Considering Calypso must have been with Plusnet a long time to have such an old Thomson, perhaps Plusnet would send a new router for just the cost of the postage & packing - which would be less than another filter from Maplin. I think Plusnet said they'd sent out extra filters for free, but that was because the 2704N is supplied with only one filter, whereas the previous router came with two.
