Loss of connection
- Loss of connection
Loss of connection
05-02-2014 5:13 PM
I tried to call earlier about this but as the wait time was estimate to be 45minutes and I waited over an hour I figure I'm better off posting here.
So, my internet lost connection around (give or take a few minutes) on the 4th February at 22:05 GMT, at which point I couldn't connect for about 10 minutes and had errors such as "DSL down" when logging in as admin. After that, I was getting extremely slow connection speeds (~1-2mbps as opposed to my usual 16-17mbps) for a couple of hours; coming to use my computer again today at 5PM I wasn't able to connect to the internet at all, not even able to log in the router, which would indicate the router is the issue however I'm hoping you can check on your end to see what caused the disconnect(s). I was able to connect just now by restarting the router, luckily.
Message 1 of 6
(922 Views)
5 REPLIES 5
Re: Loss of connection
05-02-2014 5:31 PM
Hi Afran,
Apologies for the problems you're experiencing. We're having problems with one of our gateways (PTW-AG01) which you were connected to at the time. You've now connected to a different gateway which isn't affected so you should see an improvement.
Please let us know if you have any further issues.
Message 2 of 6
(610 Views)
05-02-2014 10:33 PM
Hi Chris,
Thanks for the fast reply.
Unfortunatley a disconnect just occured in a similar fashion to before, aprox. 22:30 GMT
Message 3 of 6
(610 Views)
05-02-2014 10:59 PM
It might be worth visiting http://faults.plus.net and completing the questions there so we can take a closer look at the line for you.
Message 4 of 6
(610 Views)
05-02-2014 11:06 PM
"Broadband Troubleshooter - Error
There's been a problem
Please try using the Broadband Troubleshooter again in a short while. If you continue to have problems please contact our Support Team for help."
Hmm, well I would if I could, heh.
Message 5 of 6
(610 Views)
06-02-2014 9:21 AM
We've received your Fault Report - we'll be back in touch as soon as one of the guys on the Faults Team gets your line looked at.
Message 6 of 6
(610 Views)
