Loss of DNS
- Loss of DNS
Loss of DNS
Loss of DNS
19-06-2013 7:24 AM
Happened again just 5 minutes ago. I'm on ptw-ag02. tho' the other day I was 07 [not sure of the full designation]. I was just about to go restart my pc when it came back.
Is this a PN problem or mine?
Re: Loss of DNS
Re: Loss of DNS
19-06-2013 1:43 PM
The connection's been fairly stable from our point of view:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13716456354250.png"/>
Noticed a reduction in speeds?
Also just wondering if you normally connect via wireless and have done what you can to rule that out in case that's a potential cause.
Adam
Adam Walker Plusnet Help Team |
Re: Loss of DNS
Re: Loss of DNS
20-06-2013 4:35 PM
My speeds have dropped about 0 .7Mb I was getting 4.8 - 4.9Mb now on a good day recently I get 4.3Mb slower some days.
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 6040 955
Noise Margin 6 5
Output power(dBm) 14 0
Attenuation(dB) 49 27
Re: Loss of DNS
Re: Loss of DNS
23-06-2013 8:50 AM
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 5144 987
Noise Margin 8 7
Output power(dBm) 12 19
Re: Loss of DNS
Re: Loss of DNS
24-06-2013 9:31 AM
Re: Loss of DNS
Re: Loss of DNS
01-07-2013 7:36 AM
from the attached you can see the speed tests I was getting but getting pings of 50ms or more, is this acceptable?
Looking at my router stats I can see I was getting reports of ...
06/28/2013 08:34:07 ADSL Media Up !
06/28/2013 08:33:21 PPPoE stop
06/28/2013 08:33:21 PPPoE1 stop PPP
06/28/2013 08:33:21 ADSL Media Down !
Does this mean loss of connection and would they be recorded by PN?
Re: Loss of DNS
Re: Loss of DNS
01-07-2013 9:08 AM
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
Re: Loss of DNS
Re: Loss of DNS
01-07-2013 9:48 AM
I am seriously considering paying £130 or so to get OR to move the master socket. When they installed the new socket he didn't tell me until he was leaving that I had to have my router plugged into it and not an extension.
Re: Loss of DNS
Re: Loss of DNS
01-07-2013 9:58 AM
If it is due to the wireless, homeplugs may be a cheaper solution.
If it's not the wireless, proof of that is needed before you can take the issue further with Plusnet.
