Losing connection
PhilB1
Losing connection
Hope someone can help. Over the past 4 to 5 days my broadband keeps dropping out. I have brought a new router and still having the same problems. The router is plugged straight into a prefiltered bt master socket. There are no phone extensions. Hope someone can take a look.
Gel
Seasoned Pro
Fixes: 12
PhilB1
Re: Losing connection
I done thw checks yesterday and raised a fault enquiry but have had no reaponse or update. When i had sky broadband before i never had any problems
MrSilver
Fixes: 9
Hi PhilB
Can you confirm what drops out, are you losing DSL sync at the router, or are you losing your PPP connection to plusnet (so DSL is synced up and showing as disconnection from ISP) or is all that up fine and you stop getting traffic from websites?
PhilB1
I check on the router settings and the dsl has disconnected.
MrSilver
Fixes: 9
Does it come back and get in sync again, like a reset or is it staying out of sync for 10+ minutes?
PhilB1
Does come back and reconnects after about a minute
MrSilver
Fixes: 9
If @Anoush is on he is usually pretty good at being able to run a copper line test. Assuming you always have the router in the master socket and no extensions for testing, i.e. its unstable when you don't plug in anything apart from the router?
PhilB1
We dont use house phones so the only thing that is plugged to the master socket is the router. Everything was fine till a few days ago. Nothing has changed inside the house. The phone line is quite old outside.
Plusnet Staff
Plusnet Staff
Fixes: 115
Sorry to hear you're having connection problems @PhilB1
If my colleagues don't get round to pick up your thread today I'll absolutely run a few tests for you tomorrow once I am back in the office.
I've run a copper line test which has passed. It looks like our faults team would like to arrange an engineer appointment to further progress the fault. Once you reply to the ticket with the requested information, we'll get it booked in for you.
I've joined the Plusnet Help Team as of May 2017. As such, I have a new forum account. Please direct any queries to @Gandalf. Thanks
 Plusnet Support
PhilB1
Ok great. I had an email saying about switching interleaving on do i still need an engineer visit or shouldi wait
Plusnet Staff
Plusnet Staff
Fixes: 115
I'd probably go for the engineer as your connection is dropping:
 Plusnet Support
MrSilver
Fixes: 9
If you are a gamer at all then try to avoid interleaving, it makes the line more stable but increases the latency on the line.
If you do video, web browsing etc like 99% of the internet you wouldn't notice interleaving, but gamers will notice the 15-20ms extra it will add.
Old external phone lines, in winter cold and wet season generally do go bad, its one of Openreaches biggest challenges. As water gets into junction boxes and freezes, weakens joints etc so over time slows lines down and can cause big problems.
Interleaving may mask some of those in the short term but as you have no in-home wiring to cause the disconnections I'd personally take the engineer.
You could try plugging the router into the test socket if you unscrew the faceplate (if you have what's called an NTE5), the faceplate doesn't really go wrong so shouldn't be an issue but it has been known in the past to slow things down.
