Looking for cheap test/replacemnt router recommendations
Gus
Looking to get a cheap router to check if my current Draytek 2800VG is dying or not, I have an old Origo but it doesn't work on ADSL2 enabled exchanges.  So for £50 or less with 4 port lan and wireless G any recommendations?
I've had a look at what broadbandbuyer.co.uk have for sale, but all the much cheapness routers with wireless have bad reviews and Thinkbroadband.com no longer actively review new routers so next port of call is here.
FTTP 500 regrade from Tues 28th November
9 REPLIES 9
Mav
Fixes: 515
Re: Looking for cheap test/replacemnt router recommendations
If you have no plans to leave PN in the next year why not ask for one of theirs and you will only need to pay p&p.
Forum Moderator and Customer
Gus
The Thompson is covered by those reviews
JEB
I recently bought a BT Home Hub 3 from Ebay.  It was a steal at £22, and it has the latest Wireless.
James
HPsauce
I'd get a cheap (£20 delivered at most) ex-Sky DG834GT on fleabay and flash it to standard.
(needs an XP system to do this)
Oldjim
Resting Legend
Fixes: 63
I would recommend a DG834G v4 if you can find one
198kHz
Fixes: 41
BT Business Hub (2Wire 2700HGV) is highly regarded and readily available cheaply on eBay.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Gus
As its possibly to be a replacement, I would rather it was new than ebay'd and suspect lifetime left.  Currently looking at the DG834G v4 after finding a link oldjim posted recently with a site selling them and a Buffalo AirStation
Oldjim
Resting Legend
Fixes: 63
Note that I have removed the link as it seems to be the non wireless variant
Gus
Went for the Buffalo anyway Jim, http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=8269 cheap enough and good enough reviews with a little digging, even if it has a poor web interface.
