Looking for a router upgrade
- Looking for a router upgrade
02-04-2013 10:47 AM
I am using the Thomson router version TG585 V8 and I was wondering if they is a chance I can get the upgraded Thomson router with the usb sharing port?. I am 90% sure been with plusnet 3 years I have never been supplied a router, my Thomson router was from eBay.
I am having some strange problems lately and want to upgrade my router on the cheap. I paid £35 for the Thomson and to be fair for its age has been awesome just lacking a needed usb slot for a printer. I also paid £40 for a netgear dgn1000 (?) and this was like throwing money into the wind. The wireless always kept dropping connection every 30 min and would not return until a hard reset was done.
I am looking for a router with usb sharing with good reviews or personal recommendation and I am looking to pay around £40 again. My most important machines are connected with powerline adapters but a consistent working wireless is a must. I will probably be heading to Amazon or ebuyer if plusnet cannot help with a upgrade.
Thanks for any help.
Re: Looking for a router upgrade
02-04-2013 11:00 AM
02-04-2013 11:31 AM
As Plusnet is a BT-group company you can run one (on ADSL) without any modification.
It has a USB port and very reliable wireless (checks for interference from nearby electrical equipment).
You can usually find them on eBay for about £15 brand new.
02-04-2013 11:50 AM
02-04-2013 12:26 PM
02-04-2013 12:33 PM
02-04-2013 1:32 PM
02-04-2013 1:45 PM
Hopefully setup will be easy and I was wondering does ''hacking'' provide any benefits ?
02-04-2013 1:55 PM
02-04-2013 1:56 PM
Of note there are two types, the Home Hub 3a and the Home Hub 3b, and only the 3a has been hacked as of yet. It does auto-install the latest firmware from BT's servers, and it seems the latest firmware update prevents the firmware from being downgraded in the future.
02-04-2013 2:05 PM
It wasawful, it worked well for a week, then the wireless went crazy, it connect at the slowest speeds.. I was sent 4 different routers by BT, all had the same problem.
Eventually I traced the issue.. every time my tv was on, it was causing the wireless AND wired to drop or come to a crawl.
As the phone socket is under the tv, what chance did I have!
The home hub 3 hates plasma tv's!
Interestingly, no other router that I have used has this problem.
My current router Netgear N900, gives exactly the same speeds via wired or wireless to my laptop and PC and is amazing, so personally I would go down that route.
My Netgear has been running for for months now with the only disconnection coming from PlusNets end.
