Look at my line stats
huggy33
Hi. I have been with plusnet for 2 months. I'm running a TP-Link modem with  Asus RT-N56U router. After the first week the performance for streaming and peer to peer was impressive, but then deteriorated. I then requested the interleaving to be turned off, 3 weeks in, and again for the first week it improved. But then since, it has gone downhill again.
Could you inform me of my line stats... since my custom Asus firmware doesn't display them. Would a snr reset be in order? I raised this issue on a ticket on the main site.... but got a "computer says no" kind of response...... along the lines of BT does this at their end and we can't alter their automatic profile performance monitors... but I know you guys on here are more helpful.
Thanks.
Fixes: 62
Re: Look at my line stats
Can you access the TP Link modem as that is where the stats would be
Sorry you were told that - it's true that we can't if you're on Fibre, but as you're on ADSL2 we can get them for you (though as Jim says if you're able to log in to the modem you should be able to see them fine).
Upstream Link Info
Loop Loss SNR Margin Errored Seconds Hec Errors Cell Count Speed
8.3         25.7         0                 0          3430         445
Downstream Link Info
10         6.1         4                 N/A         247         18235
Downstream BIP Interface Data
Current Line Rate Line Rate Change TimeStamp Maximum Stable Rate Recalculated Profile TimeStamp Maximum Stable Rate Fault Threshold Rate Interleaving Flag
16088                 11/07/2013 06:43:10         Y                                 25/06/2013 09:44:52 18176                 14541                 Off
It does look like interleaving has turned itself back on recently, not sure why but if you're seeing drops on the line that could be it. Is the modem plugged into the master socket, and is everything else plugged into the line done so through a microfilter?
huggy33
Yes it's ADSL2.... the Asus router won't give me line stats on the firmware I have. I have done all you said with regards to master socket and microfilters. Could you turn interleaving back off please. Thanks.
Just checked and it seems interleaving is back to being off at the moment (and is actually set to Opt out, so won't turn itself on again later either).
Hope that helps.
huggy33
Hi. Could you make double sure that interleaving is off for good... and could you post my latest stats thanks.
Would still like improvement but better now on fastpath. Is that right that the SNR Margin is on the default: 6?
Here's the stats:
Upstream Link Info
8.3      26.3      0              0          3786      445
10        7.8        0              N/A        313        15412
13597            05/08/2013 06:47:31        Y                                30/07/2013 19:06:29  18176              14541                O
Interleaving is still off (hence the O). Downstream SNR is still set to 6dB by default but will rise and fall depending on the line.
Upstream needs uncapping...
While it's true that the upstream is capped, and while I've no doubt you have the end user's best interests at heart, I'd rather wait for a request from the owner of the line before making any changes.
@Matt
My suggestion was aimed at the OP, not you.
huggy33
http://forums.thinkbroadband.com/plusnet/4062278-upload-speed.html?fpart=all&vc=1
Seeing this discussion, the P2P is important to me..... and uncapping the upload could make my download slightly superior. Streams sent do seem to be getting clogged and slowing down.
Could you do this, uncap the upload?
Certainly can - order's placed for you, unfortunately as it's a Friday it won't complete until Monday morning.
huggy33
Thank you. See if it makes any difference.  Smiley
huggy33
Hi. The upload is certainly greatly improved! Could you post my line stats for the final time, and just confirm that the interleaving is off for good, and the cap will remain banished forever. Thanks!
Hi there, happy to:
Upstream Link Info
8.1        6.4        0                0          5799        1071
10        6          0                N/A        3386        19234
16969              15/08/2013 06:31:18          Y                                  30/07/2013 19:06:29    18176                  14541                  O
Your account's set with the uncapped upload so that'll stay as is as well.
