Long timeouts for stale PPPoE connections
- Long timeouts for stale PPPoE connections
Re: Long timeouts for stale PPPoE connections
14-05-2013 2:17 PM
Quote from: Anotherone Thanks for your reply Bob. As some have been reporting modem reboots about as quick as 10 seconds or so, and SIN498v4p3 states retrain times can be between 10-60 seconds (para.2.1.6) wouldn't an 8 second timeout be more appropriate - what issues if any would that cause?
That's something we need a bit of time to look into.
14-05-2013 2:25 PM
What I was saying in that quote was more about the 8960n in that it had no means to do a graceful disconnect. However by opting to reboot the 8960n from its menu it rebooted very quickly and reestablished suggesting it was doing a graceful disconnect prior to the reboot?
I haven't as yet on the Asus I am now using had to reboot it soon idea if it will exhibit timeout. And I certainly don't want to try as that will No doubt jinx my current high and stable line speed lol.
14-05-2013 2:33 PM
14-05-2013 2:43 PM
Quote 2.1.6 Downstream shaping
The CP is expected to shape the downstream traffic to match the actual VDSL2 line rate in order to avoid excessive traffic loss.
CPs should be aware that the mechanism for reporting the downstream and upstream line rates relies on a line re-train causing the CP, or the CPE, to initiate a new PPP session or a new DHCP request. The success of this method of line rate reporting is down to the CP's choice of timers used around PPP/DHCP handling.
If the PPP/DHCP survives a re-train, then the CP will be unaware of any change in the line rate and will not be able to shape appropriately.
The line re-train time for VDSL2 can be anywhere between 10 and 60 seconds, with typical values in the 20-30 second range.
I appreciate this will not likely be an overnight fix, the above specifically explains why correct timing is important in keeping the Plusnet line speed setting correct to avoid dropped packets and other issues.
14-05-2013 3:13 PM
14-05-2013 3:29 PM
14-05-2013 3:59 PM
14-05-2013 5:10 PM
It would appear Sin498 contradicts itself as elsewhere it mentions the time should be no more than 20seconds despite as pointed out a retrain could be as little as 10seconds
23-05-2013 10:47 AM
I can try this myself when I get home this evening, but for the sake of speeding up our investigation is anybody able to replicate this problem today/this afternoon on their own line? i.e. powercycle the router so it gets into the state where it won't reconnect for ~8minutes. I need to consult BT's RADIUS logs however they only go back about a week.
23-05-2013 10:50 AM
Do you just want a reboot?
23-05-2013 10:57 AM
23-05-2013 11:08 AM
BT box is followed by a Draytek Vigor 2130n so can monitor that to see when the link becomes live again.
Just waiting for Bob to reply...
23-05-2013 11:32 AM
23-05-2013 11:46 AM
Power on at 11:34:00
PPP session starts at 11:40:24
Second PPP session starts at 11:40:58 - must be a Vigor thing...
CHAP completes at 11:41:00
23-05-2013 11:52 AM
